EIGRP Neighbors reset (Flapping) in DMVPN Connection
MohammadSalih
hi every one,
i have an issue with EIGRP Relationship in DMVPN connections,
the neighbor reset between the hub and the spoke
and i got the Errors:
%DUAL-5-NBRCHANGE: EIGRP-IPv4 77: Neighbor 172.19.1.36 (Tunnel191) is down: Interface PEER-TERMINATION received
%DUAL-5-NBRCHANGE: EIGRP-IPv4 77: Neighbor 172.19.1.36 (Tunnel191) is up: new adjacency
%DUAL-5-NBRCHANGE: EIGRP-IPv4 77: Neighbor 172.19.1.137 (Tunnel191) is down: Interface PEER-TERMINATION received
%DUAL-5-NBRCHANGE: EIGRP-IPv4 77: Neighbor 172.19.1.137 (Tunnel191) is up: new adjacency
%DUAL-5-NBRCHANGE: EIGRP-IPv4 77: Neighbor 172.19.1.126 (Tunnel191) is down: Interface PEER-TERMINATION received
%PIM-5-NBRCHG: neighbor 172.19.4.127 UP on interface Tunnel194
%DUAL-5-NBRCHANGE: EIGRP-IPv4 77: Neighbor 172.19.1.126 (Tunnel191) is up: new adjacency
%DUAL-5-NBRCHANGE: EIGRP-IPv4 77: Neighbor 172.19.4.127 (Tunnel194) is up: new adjacency
%DUAL-3-SIA: Route 77.77.61.0/24 stuck-in-active state in base 77. Cleaning up
%DUAL-5-NBRCHANGE: EIGRP-IPv4 77: Neighbor 172.19.1.93 (Tunnel191) is down: stuck in active
EIGRP: Build goodbye tlv for 172.19.1.93
i have VSAT connection between hub and spokes,the underlay connection work fine without any packet loss
also i have more than DMVPN connection with different underlay connection.
like Fiber optic and it works fine without any problem,
only the VSAT connection have this issue.
the configuration:
HUB
interface Tunnel191
description ** VSAT **
bandwidth 10
ip address 172.19.1.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1400
ip nbar protocol-discovery
no ip split-horizon eigrp 77
ip pim nbma-mode
ip pim sparse-dense-mode
ip nhrp map multicast dynamic
ip nhrp network-id 111
ip summary-address eigrp 77 79.0.0.0 255.0.0.0
ip summary-address eigrp 77 182.0.0.0 255.0.0.0
ip tcp adjust-mss 1360
qos pre-classify
tunnel source GigabitEthernet0/0.8
tunnel mode gre multipoint
tunnel key 111
end
Spokes
interface Tunnel191
ip address 172.19.1.126 255.255.255.0
ip mtu 1400
ip pim nbma-mode
ip pim sparse-mode
ip nhrp map multicast 172.22.8.5
ip nhrp map 172.19.1.254 172.22.8.5
ip nhrp nhs 172.19.1.254
delay 1000
qos pre-classify
tunnel source 172.22.8.242
tunnel destination 172.22.8.5
tunnel key 111
end
15 Replies 15
Can you share
Show ip eigrp traffic
Show ip traffic statistics
There is command to force eigrp to use 50% (or more) of BW of link
Router1(config-subif)#ip bandwidth-percent eigrp xx 50
 But this not answer the Q why eigrp send huge update and SIA.
Also did you try do some stub in eigrp in other traffic?
Dis you change next-hop of eigrp in hub?
MHM
