Eigrp not advertising connected network
Malick MBAYE
I have two routers
                RouterA<------------------------>RouterB
RouterB is not advertising his connected routes.
Example:  i configured an ip address 192.168.1.1/24 on an interface Vlan which is UP but when i go to RouterA and i look "show ip route eigrp" and check the routes which Router B advertise, i don't see that network but i see other network advertised by other routers behind the RouterB.
"show ip eigrp neighbor" on RouterA also show the RouterB's directly connected address
Note that i did "redistribute static connected" on eigrp configuration.
balaji.bandi
have you configured the network statement in the EIGRP process?
example :
router eigrp 100
no auto-summary
network x.x.x.x 0.0.0.255
or post the configuration of both the routers. show ip route from both the routers.
BB
balaji.bandi
example :
router eigrp 100
no auto-summary
BB
if you can specify the metric when you redistribute.
Giuseppe Larosa
Hello @Malick MBAYE ,
You complain that connected interfaces are not advertised in EIGRP , this would be an issue only if you had done on RB:
redistribute connected.
Be aware that EIGRP external routes have AD 170 internal routes have AD 90 and are preferred over the first ones.
As suggested by @MHM Cisco World you should try to use a network command to cover the connected interface(s) to generate internal routes instead of external routes.
You can check the EIGRP database using
show ip eigrp topology
a passive state P is the hormal state of a prefix.
Hope to help
Giuseppe
