EIGRP offset-list based on source IP and advertised network
tato386
Level 6
Level 6
I need to offset some networks based on what router advertised them.  Since I only need to offset some networks and not all I need the ability to not only define the router but also the subnet.  Furthermore, since I get updates from multiple routers on the same interface I can just offset everything coming in on one interface.  It seems like the ideal thing would be an extended list similar to this:
offset-list 150 in 1000 Gi0/0
access-list 150 permit ip host 1.1.1.1 192.168.1.0 0.0.0.255
Most documentation says that EIGRP supports extended lists for offset but it seems like in practice it does not work and I can't seem to get my router to take the command.
So what are my options here?
Diego
Vinit Jain
Hello Diego
how are you doing today?
Could you please share the IOS verison (show version | in image), the error message that you are getting when you apply the config.
Vinit
--Vinit
I tried using named and number.  Results below.
System image file is "bootflash:/isr4300-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin"
ip access-list extended Test
 permit ip host 1.1.1.1 192.168.36.0 0.0.0.255
access-list 160 permit ip host 1.1.1.1 192.168.36.0 0.0.0.255
4331(config-router)#offset-list Test in 2000 Tunnel1
Access-list type conflicts with prior definition
4331(config-router)#offset-list 160 in 2000 Tunnel1
% Invalid access list name.
The first problem with ACL 160 is that the range is not supported.
R2(config-router)#offset-list ?
  <0-99>       Access list of networks to apply offset (0 selects all networks)
  <1300-1999>  Access list of networks to apply offset (extended range)
  WORD         Access-list name
Regarding the extended ACL (named) Test, You cannot use extended ACL. You will have to use Standard ACL Only.
R2(config)#ip access-list standard Test
R2(config-std-nacl)#permit 192.168.36.0 0.0.0.255
R2(config-std-nacl)#exi
R2(config)#router eigrp 100
R2(config-router)#offset-list Test in 2000 e0/1
So, you will have to decide upon how you want to use the ACL in offset-list.
Hope this helps.
Vinit
--Vinit
Vinit,
I  kinda already knew what you show above, I was hoping I was doing something wrong.  Can you suggest an alternative way of achieving the route offsets that I need to do?
Diego
