PPP configuration pt
master_120001
I'm following a ppp tutorial and it's all good but theres is one issue my serial interfaces protocols are down, I don't understand why
as shown below the issue is serial 2
Router 2#sho ip int brief
FastEthernet0/0        unassigned      YES DHCP   up                    up
FastEthernet0/1        1.1.1.1         YES manual up                    down
Serial0/2/0            10.0.0.2        YES manual up                    down
Serial0/2/1            unassigned      YES unset  up                    up
Vlan1                  unassigned      YES unset  administratively down down
 I'm also getting this repeat message
Serial0/2/0 IPCP: I CONFREQ [Closed] id 1 len 10
Serial0/2/0 IPCP: O CONFACK [Closed] id 1 len 10
Serial0/2/0 IPCP: O CONFREQ [Closed] id 1 len 10
Serial0/2/0 IPCP: I CONFACK [Closed] id 1 len 10
Vinit Jain
Could you share the running config from both the routers in a file along with the debug ppp negotiation output.
--Vinit
