10-22-2013 01:01 PM - edited 03-04-2019 09:23 PM
hi,
Eigrp running on all three routers, i try to ping from r3 to r1 loop address after the ping starts and i did manually shut down the r1 ehternet connection the pings start losing packets and it take more then 10 seconds to reach ping from r2 to r1 loop. is there anyway to avoid this problem.
Solved! Go to Solution.
10-22-2013 01:26 PM
If you detect the neighbour failing quicker and if your secondary path is a feasible successor then it can be quicker.
For this you can use lower hello/holdtime timers or use BFD.
Alain
10-22-2013 01:26 PM
Alain
10-22-2013 01:34 PM
hi,
some of my friends said that the switch running STP on each port and requiring 30 seconds to proceed through Listening and Learning states until a port transitions to the Forwarding state. if i confiure the switch to rstp and make the three ethernet port to spanning-three port fast and acces port can avoid this problem ?
10-22-2013 05:41 PM
If you enabled the EIGRP process, and the router from which you enabled the EIGRP process, connects to it's neighbors via a switch, it's completely possible that, if you're using 802.1D it will take 30 seconds by default, for the port to come up, if portfast is not configured. Since by default, the EIGRP default hello timer is 5 seconds and hold time is 15 seconds for this type of network. So it's completely possible that STP could cause this issue.
10-23-2013 01:05 AM
Hi feroz ,
If you feel that spanning-tree timers causing problem you can use spanning-tree portfast command on all port connected to routers and i dont thing there would be any loop problem occur as you have only one switch in network as well all routers port are L3.
Ashish Shirkar
10-23-2013 01:14 AM
Already i configure portfast on all three switch ports, but didn't see any effect after shutdown the r1 ethernet port.Am going to try as Alain said to lower the hello interval and hold-down interval.
10-23-2013 12:10 PM
Thanks working perfecctly now
