EIGRP redistribute static and routes to Null0
joan.luque
Hi all,
I have encountered some weird behaviour in a Cisco router regarding the eigrp redistribution when I have static redistribution and static routes to Null0 at the same time. I will explain:
Some days ago I used routes to Null0 in order to advertise some routes in our LAB EIGRP domain and test some NAT options:
router eigrp 10
 network 1.1.1.0 0.0.0.255
ip nat pool Pool_Customer_A 1.1.1.10 1.1.1.20 prefix-length 24
ip nat inside source list ACL_NAT_Customer_A pool Pool_Customer_A
ip route 1.1.1.0 255.255.255.0 Null0
ip access-list standar ACL_NAT_Customer_A
 permit 10.1.1.0 0.0.0.255
With the configuration above all work as expected.
Some days later I tried with the same router to rise other customer traffic. I have used static routes to reach this traffic across a second router and redistribute these static routes via EIGRP to enable the return path. I have use the following configuration:
router eigrp 10
 redistribute static route-map MAP_STATIC_TO_EIGRP
ip route 2.2.2.0 255.255.255.0 3.3.3.1
ip access-list standard ACL_REDISTRIBUTE_STATIC
permit 2.2.2.0 0.0.0.255
route-map MAP_STATIC_TO_EIGRP permit 10
 match ip address ACL_REDISTRIBUTE_STATIC
When I added the configuration above the router stop redistribute the static route to Null0. The only way that I found to solve that was defining a loopback interface with an ip in the range that I would redistribute:
interface loopback 1
 ip address 1.1.1.1 255.255.255.0
From my point of view this is a really strange behaviour. Maybe I miss something importanta ...
Someone can bring some clue about this?
Hello
As you may know, When  specifying a network command associated with an active interface eigrp would indeed advertises it.
However if you redistribute static pertaining to a null interface(virtual interface) and you have an active interface with the same subnet address eigrp wont advertise it as it is now NOT a NUL interface.
Also if you redistribute static via route-map it will only advertise what  statics are associate with the route-map and acl
Try removing the network statement from eigrp and the loopback interface and adding the subnet to the exiting acl, which should advertise the two statics as external eigrp routes.
no int lo0
router eigrp 10
no network 1.1.1.0 0.0.0.255
permit 1.1.1.0 0.0.0.255
res
Paul
Kind Regards
Paul
Richard Burts
It seems fairly straightforward to me. You are redistributing static routes into EIGRP using a route map to control the redistribution. The route map uses an access list to identify the routes to redistribute. The access list has a permit only for 2.2.2.0 and not for 1.1.1.0. So 1.1.1.0 is no longer redistributed.
Rick
Rick
Hello
no int lo0
router eigrp 10
res
Paul
Kind Regards
Paul
