EIGRP Route Filtering with ACL issue
trilerian1
I am doing route filtering with acl for an EIGRP AS.  I have an issue with two /24 of a /20 that are coming through even though there is a deny statement for those networks.
The subnets in particular are 172.26.110.0/24 and 172.26.120.0/24
Here is my ACL
access-list 5 remark Filter incoming routes from Somewhere
access-list 5 deny 172.26.110.0 0.0.0.255
access-list 5 deny 172.26.120.0 0.0.0.255
access-list 5 permit 172.26.0.0 0.0.255.255
access-list 5 deny any
Here is my EIGRP config for this AS.
router eigrp Somewhere
address-family ipv4 unicast autonomous-system 2
af-interface default
passive-interface
exit-af-interface
af-interface Vlan1023
no passive-interface
exit-af-interface
topology base
distribute-list 5 in Vlan1023
redistribute eigrp 10
exit-af-topology
network 10.162.23.0 0.0.0.255
eigrp stub connected redistributed
exit-address-family
And when I do a show ip route, the bolded routes come through even though I am denying part of the subnet.
172.26.0.0/16 is variably subnetted, 14 subnets, 6 masks
D EX 172.26.0.0/20 [170/51722240] via 10.162.23.253, 1w0d, Vlan1023
D EX 172.26.0.254/32 [170/117760] via 10.162.23.253, 1w0d, Vlan1023
D EX 172.26.32.0/21 [170/51722240] via 10.162.23.253, 1w0d, Vlan1023
D EX 172.26.48.0/20 [170/51722240] via 10.162.23.253, 1w0d, Vlan1023
D EX 172.26.64.0/19 [170/51722240] via 10.162.23.253, 1w0d, Vlan1023
D EX 172.26.96.0/20 [170/51722240] via 10.162.23.253, 1w0d, Vlan1023
D EX 172.26.112.0/20 [170/51722240] via 10.162.23.253, 1w0d, Vlan1023
D EX 172.26.128.0/20 [170/51722240] via 10.162.23.253, 1w0d, Vlan1023
D EX 172.26.144.0/20 [170/51722240] via 10.162.23.253, 1w0d, Vlan1023
D EX 172.26.160.0/20 [170/51722240] via 10.162.23.253, 1w0d, Vlan1023
D EX 172.26.224.0/24 [170/51722240] via 10.162.23.253, 1w0d, Vlan1023
D EX 172.26.252.0/22 [170/51722240] via 10.162.23.253, 1w0d, Vlan1023
Can you not deny part of a bigger subnet that you are allowing through? I've added static routes to the /24 networks so the routing is fine, but I would like the route filtering to work.
Those two /24 are not in the route table just the the smmary is.
If you summarize a subnet as long as a single network/interfface related to the larger subnet is active and in the route table the summary will be advertised.
Kind Regards
Paul
13 Replies 13
Edited as I didnt see the distribute list applied.
Are you able to ping the devices that you are trying to block form that device?
If you are only blocking part of the subnet it will still allow the subnet as a whole to be advertised. It looks to be working as intended.
-David
Thanks, I will look into a prefix list.
can you check
show access-list
see if match is hit the 0.0.0.255 or 0.0.255.255
share here if you can
It is interesting that all of the routes that you show us are external. And it is interesting that the eigrp config that you post is for AS 2 and includes
What can you tell us about eigrp 10?
Rick
This router is an edge router and redistributes routes from two different AS to the other based on ACL filtering.  I guess the ACL needs to change or I need to come up with something different.  When I started researching how to filter the routes there were three different methods: ACL, prefix, and route map.  I think I am going to go look at route maps.
Kind Regards
Paul
Quick question.  If on the other end, outgoing acl for filtering, if those /24s are filtered but the /16 is allowed after the deny for the /24, would it still summarize the entire /16?  If so, what is the easiest way to deny specific /24s of a /16 in a filter?
The reason why I need to do this: routes that I don't want to come through are part of ipsec tunnels on the firewall, so I don't want these other routes to exist at all.  On this router I can create more specific routes to the firewall for those networks, and that is what I have done.  But the idea is to filter out any unwanted routes to begin with.
can you share the
show access-list ?
I want to see which line is hit and which not hit
for me I always use
prefix-list
not ACL
https://loopedback.com/2017/05/10/eigrp-deep-dive-into-prefix-list-configurations-access-list-vs-prefix-list-using-prefix-lists-to-filter-eigrp-routes-with-distribute-lists/
60 deny 172.26.110.0, wildcard bits 0.0.0.255
70 deny 172.26.120.0, wildcard bits 0.0.0.255
90 permit 172.26.0.0, wildcard bits 0.0.255.255 (24 matches)
Looks like it does nothing with those /24s.  But, they are also smaller parts of those routes, I wonder if I deny the /20 if it would still show...
https://ine.com/blog/2008-01-04-using-extended-access-lists-in-a-distribute-list
check this link, I think you need to more modify wildcard 0.0.255.255 <<-
Replying to my own post.  That did the trick...
60 deny 172.26.96.0, wildcard bits 0.0.15.255 (2 matches)
70 deny 172.26.112.0, wildcard bits 0.0.15.255 (2 matches)
90 permit 172.26.0.0, wildcard bits 0.0.255.255 (20 matches)
Yes, as I mention before I prefer use
prefix-list,
and if you use distribute access list always check it with
show access-list
to modify it.
good job Friend.
I am a bit confused about what is going on here. The
show access list
does not show any hits on the deny /24 statements but does show hits on the deny /16 statement. I do agree that using a
prefix list
might be more effective here and an access list.
Rick
