EIGRP Route Selection problem
ayokunles
Hi all,
I have a challenge with EIGRP route Selection.
the router is using the route with the highest composite metric to route to the network despite the fact that the network is directly connected to its interface. it prefers to take the one of the longest route with 5 hops to reach a destination that is just one hop away.
From the diagram attached Traffic meant for the server farm coming from remote sites comes in through DC CORE RTR1 then it goes over the fiber to HQ CORE RTR1 (which it should not) then to HQ CORE SW1 or HQ CORE SW2 and then over the radio to DC CORE RTR2 and then to either DC CORE SW1 or DC CORE SW2 to the Server farm switch.
and i do not know why.
I'm in a fix and really need help here.
thanks all.
   Please provide the detailed information regarding your topology. You think the remotes sites should go through DC Core RTR1 and then DC Core SW1 and then Server farm switch. Right? If so,please post the configuraion on all related devices.
HTH,
Toshi
hi,
please post the config of DC Core RTR1.
Kishore
