EIGRP route summarization
vault
Hey everyone
I'd read once that auto-summarization won't work if a router connected to the same classful address.
So I use manul summarization with ip summary-address if-subcommand
Here's what I got
R1-(gi0/0)---10.0.12.0/30---(gi0/0)-R2
Router R2 performs summarization for networks 10.0.0.0/24, 10.0.1.0/24, ..., 10.0.7.0/24:
configuration ommited
interface gi0/0
  ip summary-address eigrp 1 10.0.0.0/21
the problem is that R2 doesn't send that route (it doesn't appear in wireshark)
Using GNS3 with c7200-advipservicesk9-mz.152-4.S5 image
Thanks in advance
The problem occured because of my inattentiveness
Previously I issued the command ip summary-address 10.0.0.0/21 with mentioning AD of 255 at the end
Then I deleted it and tried again, but that command added "summary-metric" parameter under my eigrp config mode. Now I deleted it and everything works fine
Thanks for replying
which networks are you advertising under the EIGRP process ? For the sake of simplicity, try to advertise all networks, and see if the other side receives the summary:
R2
interface gi0/0
router eigrp 1
network 0.0.0.0
Eigrp is active on every interfaces
Thanks for replying
Hello
You need to advertise at least one prefix pertaining to the summary, otherwise the summary will not get advertised.
res
Paul
Kind Regards
Paul
