03-30-2006 07:07 PM - edited 03-03-2019 12:15 PM
IOS
c1700-advsecurityk9-mz.123-14.T5.bin
Why do I have to remove the command
ip verify unicast source reachable-via rx allow-default allow-self-ping
from the interface to get DHCP to work to my ISP?
Interface config
interface Ethernet0/0
description Outside LAN
bandwidth 384000
ip address dhcp
ip access-group allowed
no ip redirects
ip inspect myfirewall out
ip nat outside
ip virtual-reassembly
full-duplex
crypto map r2d2
ip inspect audit-trail
ip inspect udp idle-time 1800
ip inspect dns-timeout 7
ip inspect name firewall tcp timeout 3600
ip inspect name firewall udp timeout 15
ip inspect name firewall http java-list 1 timeout 3600
ip inspect name firewall icmp alert off
ip inspect name firewall ftp timeout 3600
ip inspect name firewall smtp timeout 3600
ip inspect name firewall sqlnet timeout 3600
ip inspect name firewall tftp timeout 30
ip inspect name firewall cuseeme timeout 3600
ip inspect name firewall h323 timeout 3600
ip inspect name firewall realaudio timeout 3600
ip inspect name firewall streamworks timeout 3600
ip inspect name firewall vdolive timeout 3600
ip inspect name firewall fragment maximum 256 timeout 1
ip inspect name firewall netshow timeout 3600
ip inspect name firewall rtsp timeout 3600
ip inspect name firewall sip timeout 3600
ip inspect name firewall skinny
The only way I can get DHCP to work is to remove the DDOS commands on the E0/0 interface.
I read up on this command a little and it states
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hsec_r/sec_i2h.htm#wp1147566
Note If the source address of an incoming packet is resolved to a null adjacency, the packet will be dropped. The null interface is treated as an invalid interface by the new form of the Unicast RPF command. The older form of the command syntax did not exhibit this behavior.
I dont want to loose the features this commands offers for DOS attacks but with it enabled DHCP breaks.
anyone have any suggestions?
Solved! Go to Solution.
03-31-2006 05:46 AM
Perhaps one could spice up the "ip verify unicast" with an access-list.
Maybe like so:
ip verify unicast source reachable-via rx allow-default allow-self-ping 101
access-list 101 permit udp any eq bootps any eq bootpc
03-30-2006 07:11 PM
You do have a default route pointing to your ISP, don't you ?
Paresh
03-30-2006 08:51 PM
There is no default route set as I get that from the DHCP server.
03-30-2006 08:57 PM
It seems that this may be the reason that the RPF check is failing. It might be worth tryin something like the following:
ip route 0.0.0.0 0.0.0.0 Ethernet0/0 192.168.1.1 200
The 192.168.1.1 is just a dummy address (pick any address that you don't use in your network).
The above should result in the RPF check passing and then the default route learned via DHCP will be installed in preference to the above static (which I've used an admin distance of 200 for).
Never tried such a thing myself but it's worth a shot.
Hope that helps - pls rate the post if it does.
Paresh
03-30-2006 09:04 PM
Actually, I don't think you need the dummy next-hop, just try the following:
ip route 0.0.0.0 0.0.0.0 Ethernet0/0 200
Paresh
03-30-2006 09:21 PM
Wouldn't the router always use this default route, and not the one it gets by DHCP?
I mean the default route learned by the DHCP server has an administrative distance of 254, so this one is better, wright?
And since this is pointing to an Ethernet interface, you would end up with a huge arp table, before the router runs out of memory.
03-30-2006 11:58 PM
OK, I hadn't realised that the default installed through DHCP had an AD of 254. If that is the case, you are correct and what I suggested will not work at all.
Paresh
03-31-2006 05:46 AM
Maybe like so:
03-31-2006 08:18 AM
Great Idea. Let me try that this evening and Ill let you know how it goes.
12-20-2017 11:55 PM
I know this is a very old thread. But I just came across it today. IMO, adding the suggested ACL will basically defeat the source verification because any traffic on UDP 67/68 (forgot which one) is unrestricted.
Strangely, it seems the ip verify config only affect some specific DHCP clients. Most devices are not affected. I am still trying to figure out why.
