EIGRP Static route pointing to NULL 0
mudasir05
Hello Everyone,
I was just going through one of the labs in EIGRP in which I created two static routes both pointing to Null0.
However I observed that one of them got advertised and the other didn't.
R3#sh run | sec ip rou      ##router on which static route was created
ip route 11.0.0.0 255.0.0.0 Null0
ip route 55.55.55.0 255.255.255.0 Null0
R2#sh ip route    ###the neighbor router on which one of the static route was advertied but not the other.
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C    192.168.12.0/24 is directly connected, FastEthernet0/0
     1.0.0.0/24 is subnetted, 1 subnets
D       1.1.1.0 [90/409600] via 192.168.12.1, 00:05:37, FastEthernet0/0
     2.0.0.0/24 is subnetted, 1 subnets
C       2.2.2.0 is directly connected, Loopback0
     3.0.0.0/24 is subnetted, 1 subnets
D       3.3.3.0 [90/409600] via 192.168.23.3, 00:05:29, FastEthernet0/1
C    192.168.23.0/24 is directly connected, FastEthernet0/1
D    11.0.0.0/8 [90/281600] via 192.168.23.3, 00:05:29, FastEthernet0/1
Can anyone plz have a look and throw some light.
2 Accepted Solutions
Thank you for posting the configuration of both routers. It does make clear that there is not any filtering of routes on either router.
I believe that this behavior reflects the use of the statement network 0.0.0.0 under router EIGRP. There are two networks associated with interface Null 0 and EIGRP is picking up only one of them. I am not clear whether it is matching on the first one in the configuration or on the lowest numerical value. I do not believe that it is a question of classful vs classless behavior. I believe that if you were to change the static routes to this that the behavior would be the same
ip route 11.11.11.0 255.255.255.0 Null0
ip route 55.0.0.0 255.0.0.0 Null0
It would also be interesting to see what happens if you add network statements for both networks under router EIGRP
router eigrp 100
network 11.0.0.0
network 55.0.0.0
note that I am suggesting adding these to the existing network 0.0.0.0 and am not suggesting changing or eliminating it. Though it would also be interesting to see the results if you remove network 0.0.0.0 and put in network statements for the specific networks that you want to be advertised.
Rick
Rick
Hello.
That is (probably) because of bug in 12.4 IOS, that is not putting "classless" prefixes into EIGRP topology, unless you have any other classless prefix already available (in RIB).
11.0.0.0/8 is a classful prefix; 55.55.55.0/24 is "classless" prefix.
13 Replies 13
Mudasir,
Plz show your Eigrp  config on R3# most probably here is the problem.
Actually two possible reasons:
1) advertise route with wrong mask
2) Distribute-list  is filtering the route
Kazim Abbas
"Don't forget to select correct answer and rate for helpful posts"
Thanks Kazim for the reply.
The Eigrp config on R3 is as:
R3#sh run | section ei
router eigrp 1
 network 0.0.0.0
 no auto-summary
Actually this problem created some more confusions  is it possible that only classful addresses get redistributed automatically in Eigrp and not classless,and,
what will be  the case if these addresses don't exist on any physical interface or loopback.
Hope u got my point.
Hello.
There is a difference in behavior on 12.4 and 15.x IOSs.
In 15.2 all the networks (in you case) would be put into eigrp toppology.
But when (on 12.4(15)T13) I created loopback with 55.1.1.1/32 on the router, it started advertising 55.55.55.0/24 prefix.
I would say it looks like a bug (or a feature) on old IOSs.
Thanks Vasilii for the reply,
I guess so....the issue might be with the new and old versions of ios.
Would you post the output of show ip interface brief from R3? It might also be helpful if you would post the output of show ip route from R3.
Rick
Rick
Hey Rich plz have a look:
R3#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES unset  administratively down down
FastEthernet0/1            192.168.23.3    YES manual up                    up
FastEthernet1/0            192.168.13.3    YES manual up                    up
Loopback0                  3.3.3.3         YES manual up                    up
R3#sh ip route
D    192.168.12.0/24 [90/284160] via 192.168.13.1, 00:04:59, FastEthernet1/0
D       1.1.1.0 [90/156160] via 192.168.13.1, 00:04:59, FastEthernet1/0
C    192.168.13.0/24 is directly connected, FastEthernet1/0
D       2.2.2.0 [90/409600] via 192.168.23.2, 00:04:59, FastEthernet0/1
C       3.3.3.0 is directly connected, Loopback0
     55.0.0.0/24 is subnetted, 1 subnets
S       55.55.55.0 is directly connected, Null0
S    11.0.0.0/8 is directly connected, Null0
Thank you for the additional information. What I find interesting is that R2 sees the route as EIGRP internal route. If it were redistributed it would be EIGRP external. So it looks like EIGRP has matched 11.0.0.0 with your network statement. Does R3 use the network 0.0.0.0 similar to what you show for R2?
To understand what is going on and why the 55.55.55.0 is not advertised we may need to see more of the config of R3 and perhaps also of R2.
Rick
Rick
On R3 there is no filtering or any such thing.
plz find the config of R2:
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
no ip icmp rate-limit unreachable
ip cef
ip tcp synwait-time 5
no ip domain lookup
interface Loopback0
 ip address 2.2.2.2 255.255.255.0
interface FastEthernet0/0
 mac-address c200.04ec.2222
 ip address 192.168.12.2 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 mac-address c200.04ec.2100
 ip address 192.168.23.2 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet1/0
 no ip address
 shutdown
 duplex auto
 speed auto
router eigrp 100
 network 0.0.0.0
 no auto-summary
ip classless
no ip http server
no ip http secure-server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
Also on R3:
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
interface Loopback0
 ip address 3.3.3.3 255.255.255.0
 no ip address
 shutdown
 duplex auto
 speed auto
 mac-address c200.04ec.3333
 ip address 192.168.23.3 255.255.255.0
 duplex auto
 speed auto
 mac-address c200.04ec.3100
 ip address 192.168.13.3 255.255.255.0
 duplex auto
 speed auto
router eigrp 100
 network 0.0.0.0
 no auto-summary
ip classless
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
router eigrp 100
network 11.0.0.0
network 55.0.0.0
Rick
Rick
Thanks for the suggestions,
When i issued network commands on R3 for both the networks ,they got advertised on R2 keeping network 0.0.0.0 as it is.....
On R3
R3#sh run | sec eig
router eigrp 100
 network 11.0.0.0
 network 55.55.55.0 0.0.0.255
 network 0.0.0.0
 no auto-summary
R2 Routing Table
R2#sh ip route
D       1.1.1.0 [90/409600] via 192.168.12.1, 00:03:47, FastEthernet0/0
D    192.168.13.0/24 [90/284160] via 192.168.23.3, 00:03:49, FastEthernet0/1
                     [90/284160] via 192.168.12.1, 00:03:49, FastEthernet0/0
D       3.3.3.0 [90/409600] via 192.168.23.3, 00:03:47, FastEthernet0/1
D       55.55.55.0 [90/281600] via 192.168.23.3, 00:03:48, FastEthernet0/1
D    11.0.0.0/8 [90/281600] via 192.168.23.3, 00:03:48, FastEthernet0/1
Also when i removed network 0.0.0.0 from both the routers,it still were present in the routing tables:
R3#sh run | sec ei
router eigrp 100
 network 11.0.0.0
 network 192.168.13.0
 network 192.168.23.0
 no auto-summary
R2#sh ip route
D       1.1.1.0 [90/412160] via 192.168.23.3, 00:02:24, FastEthernet0/1
D    192.168.13.0/24 [90/284160] via 192.168.23.3, 00:02:24, FastEthernet0/1
D       55.55.55.0 [90/281600] via 192.168.23.3, 00:02:53, FastEthernet0/1
D    11.0.0.0/8 [90/281600] via 192.168.23.3, 00:02:54, FastEthernet0/1
 Now iam confused with the thing that why earlier 11.0.0.0 got advertised on R2 without the network command and not 55.55.55.0.
Hello.
Thanks Vasilii and Rick for your help.
