EIGRP trouble
muskap
Im trying to connect the routers via eigrp but am having difficulty with connecting the routers. Im using a 172.16.59.0 for the pcs and 192.168.59.0 for the routers. I removed the static routes for the routers to add eigrp as well. Im not sure how the command for setting eigrp is supposed to be but i used with no luck:
router eigrp 100
network 192.168.59.0
balaji.bandi
you need to provide what router image you using to understand better.
basic config should work as expected below :
R1 -----R2
R1 (Gig1) -------Gig1 (R2)
R1
Interface Gig1
ip addresss 192.168.59.1 255.255.255.0
no shutdown
R2
Interface Gig1
ip addresss 192.168.59.2 255.255.255.0
no shutdown
R1(config)#router eigrp 1
R1(config-router)#no auto-summary
R1(config-router)#network 192.168.59.0
R1(config-router)#network 172.16.59.0
R2(config)#router eigrp 1
R2(config-router)#no auto-summary
R2(config-router)#network 192.168.59.0
R2(config-router)#network 172.16.59.0
show ip eigrp
summary (you should see neighbourhsip)
still not working post complete config from R1 and R2
show run
BB
balaji.bandi
R1 -----R2
R1
Interface Gig1
no shutdown
R2
Interface Gig1
no shutdown
show ip eigrp
show run
BB
show ip eigrp
interface in both router share it
Hello
This will not work unless that subnet is divided, can you post the rtrs ip interfaces
show ip interface brief
Kind Regards
Paul
