EIGRP Unequal bandwidth load balancing
                  I need best configuration need to be implement for EIGRP unequalbandwidth load balancing.. Going to terminate the two links in the same router in different interface..
Let assume WAN IP will be 192.168.10.1 and 192.168.20.1 (just example) respectively for different interafce..
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Are you just looking to find how to do unequal EIGRP load balance, or what do you mean by "best"?
For the former, you might look at:
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094cb7.shtml#loadbalancing
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009437d.shtml
PS:
BTW, unless you fully understand the impact, avoid any per-packet load balacing.
