EIGRP updates on Serial links!!
Talha Ansari
Recently I was studying EIGRP on a lab scenario and noticed a strange thing.
I connected three routers in a chain
R1---------R3--------R2
The connection between R1 and R3 is direcly connected ethernet with a cross cable while the connection between R3 and R2 is a serial connection.
The network between R1 and R3 is 192.168.1.0/30 and the network between R3 and R2 is 172.168.1.0/30 while the routers R1, R2 and R3 are configured with loopbacks 1.1.1.1, 2.2.2.2 and 3.3.3.3 respectively.
1) If I configure neighborship between R1 and R3(ethernet connection) by simply advertising networks by the network command the neighborship forms on the basis of multicast.
2) And if I configure neighborship between R3 and R2(Serial link) by advertising networks in the eigrp process the neighboship forms on multicast.
3) But when I check the output of "show ip eigrp interface details" I observe that the serial interface shows as to use unicast updates although I m not using the neighbor command.
R3#sh ip eigrp int det
IP-EIGRP interfaces for process 10
                        Xmit Queue   Mean   Pacing Time   Multicast    Pending
Interface        Peers  Un/Reliable  SRTT   Un/Reliable   Flow Timer   Routes
Et0/1              1        0/0        55       0/2          196           0
  Hello interval is 5 sec
  Next xmit serial <none>
  Un/reliable mcasts: 0/5  Un/reliable ucasts: 11/5
  Mcast exceptions: 1  CR packets: 1  ACKs suppressed: 0
  Retransmissions sent: 1  Out-of-sequence rcvd: 0
  Authentication mode is not set
  Use multicast
Se1/0              1        0/0        74       0/15         335           0
  Un/reliable mcasts: 0/0  Un/reliable ucasts: 10/17
  Mcast exceptions: 0  CR packets: 0  ACKs suppressed: 8
  Retransmissions sent: 0  Out-of-sequence rcvd: 0
  Use unicast
R3#
I did "debug ip packet detail" to verify this and observed that the updates on the serial are indeed sent to the multicast ip 224.0.0.10. Even if I ping 224.0.0.10 I do receive replies from the serial ip address of the neighbor router.
I m attaching the details of the router R3. Is this the correct behavior/output or m I missing some point?
Talha
paolo bevilacqua
Be reassured, it's correct behavoir.
Ok thanks... was just confused as why does it always show unicast on serial interfaces... may be because its p2p link... just a guess!!
Talha
