EIGRP Variance
john.pepper
Our customer wants load-balance across unequal circuits due to the primary link being saturated. Primary link is 10Mb and backup is 4mb (multilink 2 x 2Mb).
I have tried implementing this using ‘variance’ under EIGRP on the 6500 switch but can’t seem to get both WAN routes in the routing table - unless I use the same metric on the route-maps we use for redistribution – e.g. set metric 10000 100 255 1 1500
If I do this the 6500 sees both routes but I’m concerned too much traffic will go via the lower speed link causing more problems. I have adjusted the delay under redistribution to make the 4Mb less preferred and I see this under ‘show ip eigrp top’ and thought the ‘variance’ command on the 6500 switch would work. But no matter what I set variance to it still doesn’t enter the less preferred route in the routing table.
I’m guessing this is down to the FD of the other route.? Any help is appreciated.
Thanks...John
Topology is as follows:
____
       |----2800---WAN (10Mb)
6500]
____|----3640---WAN (4Mb)
We use BGP on the WAN and redistribute into EIGRP on the LAN using route maps as follows:
2800 (10Mb)
router eigrp 5555
redistribute bgp 888 metric 10000 200 255 1 1500 route-map bgp-eigrp
no auto-summary
router bgp 888
redistribute eigrp 5555 route-map eigrp-bgp
route-map bgp-eigrp permit 30
description set eigrp metric and set tag
route-map eigrp-bgp permit 20
description permit all other routes learned via EIGRP
3640 (4Mb)
router eigrp 5555
redistribute bgp 888 metric 4000 400 255 1 1500 route-map bgp-eigrp
router bgp 888
redistribute eigrp 8001 route-map eigrp-bgp
set metric 4000 200 255 1 1500
6500
Topology entry for 10.10.10.0 /24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 281856
192.168.1.2 (Vlan1), from192.168.1.2 Send flag is 0x0
      Composite metric is (281856/281600), Route is External
     Vector metric:
       Minimum bandwidth is 10000 Kbit
       Total delay is 1010 microseconds
       Reliability is 255/255
       Load is 1/255
       Minimum MTU is 1500
       Hop count is 1
     External data:
       Originating router is 192.168.2.7
       AS number of route is 888
       External protocol is BGP, external metric is 0
       Administrator tag is 999 (0x000003E7)
192.168.1.3 (Vlan1), from192.168.1.3 Send flag is 0x0
     Composite metric is (1341696/1341440), Route is External
     Vector metric:
       Minimum bandwidth is 4000 Kbit
       Total delay is 2010 microseconds
       Load is 1/255
       Minimum MTU is 1500
       Hop count is 1
     External data:
       Originating router is 192.168.3.7
Richard Burts
John
For unequal cost load balancing to work the higher cost link must qualify as a feasible successor. From the topology table information in your post the alternate link is not a FS. You need to get the metrics closer to each other to get unequal cost load balancing.
Rick
Rick
6 Replies 6
Marwan ALshawi
this link is  blog from INE very good one to understand EIGRP loadbalncing
http://blog.ine.com/2009/05/01/understanding-unequal-cost-load-balancing/
if helpful Rate
Thank you, this helps.
Richard Burts
John
Rick
Rick
Rick,
Thank you..
Problem is I can't get seem to get the alternate link to be a FS unless I match exactly the bandwiidth/delay etc. on the redistribution from the 4mb router - e.g.
If I do this I see the alternate route as a FS and don't really need the variance command.  Trouble is then too much traffic may route across this lesser speed link.
If I adjust the bandwidth or delay down slightly I don't seem to see the router as a FS...
Any thoughts.?
Cheers
John
Joseph W. Doherty
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
Keeping in mind that EIGRP unequal-cost routing just proportionally round-robins flows, and if the primary link is truly saturated, you might not realize as much benefit as you might hope for, nor see much of an improvement over equal cost routing.
With or without any kind of multi-path load sharing, you might want to review your QoS policy.  If you're only using FIFO, you might want to consider having a QoS policy.
Instead of dynamically routing across both links, you might consider using one link for high priority or conversely low priority using PBR.
If your IOSs are new enough (3640 might be a problem), you could also consider the PIRO capable version of OER/PfR which can dynamically load balance across different bandwidth links.
Richard Burts
John
I do not know what other values you have used in your attempts to get the unequal cost load balancing to work but I would think that if the difference in redistribution metric were small that the higher cost route might qualify as a feasible successor.
In looking at the output that you posted the differences in bandwidth and delay make a very large difference in reported distance at the 6500 (281600 for one and 1341440 for the other). If you can get those numbers closer together then the load sharing might work.
Perhaps you can post an updated set of redistribution metrics and the resulting topology table on the 6500.
Rick
Rick
