EIGRP with RTO 5000
TRENT WAITE
I have two nearly identical 881 routers (15.4(1r)T1) running EIGRP that I am trying to mesh with an ASA5500X v9.8. Router 1 works, router 2 does not.
R1 (working) R2 (non-working) ASA5500
router eigrp 1
network 1.1.1.0 0.0.0.255
network 10.63.5.0 0.0.0.7
neighbor 10.63.5.1 Tunnel1
neighbor 1.1.1.100 FastEthernet4
neighbor 1.1.1.122 FastEthernet4
eigrp router-id 1.1.1.119
no eigrp log-neighbor-changes
router eigrp 1
network 10.62.5.0 0.0.0.7
neighbor 10.62.5.1 Tunnel1
eigrp router-id 1.1.1.118
router eigrp 1
distribute-list eigrp in
neighbor 1.1.1.100 interface outside
neighbor 1.1.1.118 interface outside
neighbor 1.1.1.119 interface outside
network 1.1.1.0 255.255.255.0
network 5.5.5.0 255.255.255.224
network 6.6.6.0 255.255.255.0
R2 will show as neighbors 1.1.1.100 (ASA#1) and 1.1.1.122 (ASA#2), but the RTO is 5000. I have tried removing EIGRP from R1, tried different AS #, no matter what I get is RTO 5000.
Debug eigrp transmit shows;
Aug 16 11:44:02: Building unicast STARTUP packet for 10.1.1.122, serno 0-0 for tid 0
Aug 16 11:44:02: No items in range
So far I have been unable to find anything regarding "No items in range"
Both R1 and R2 connect to the same switch the ASA is connected to, and counters R2's interface do not show any errors. I cant see where this could be a "connection" issue, especially since R1 has no issue. I believe this has to be a configuration issue. But I am unaware of where to look next. Output of eigrp neighbors:
R1
EIGRP-IPv4 Neighbors for AS(1)
H   Address                 Interface              Hold Uptime   SRTT   RTO  Q  Seq
                                                   (sec)         (ms)       Cnt Num
1   1.1.1.122              Fa4                       13 16:32:15    2   100  0  54
2   10.63.5.1               Tu1                      12 22:15:50  180  1470  0  193
0   1.1.1.100              Fa4                       12 22:15:56  243  1458  0  975
R2
                                                   (sec)         (ms)       Cnt Num
0   1.1.1.122              Fa4                       11 00:00:32    1  5000  1  0
1   10.62.5.1               Tu1                      14 00:03:15   43  1470  0  194
ASA
                                            (sec)         (ms)        Cnt Num
1   1.1.1.119              outside          14  16:32:26 1      200  0    23
0   1.1.1.100              outside          14  16:32:26 1      200  0   978
Also remove all neighbor commands from all devices, and just announce the iinterfaces...
5 Replies 5
do you have one or two ASAs ? Post a schematic drawing showing what is connected to what. Keep in mind that EIGRP uses split horizon by default...
Removing the neighbors was the answer, R2 is now showing up as a peer on the ASA. I do have a separate issue with it still having RTO of 5000 and is not re-distributing the route I need forwarded to the ASA. However the GRE tunnel will soon be going to a different router dedicated for this purpose, so I am not going to worry about this for now (it is good for learning purposes for now).
Thank you for providing a quick and easy solution
glad that you got the issue resolved...
