Email Notifications for Switches and Routers
taufeeq taufeeq
Dear All,
How may I configure switches and routers to send email notifications when link is UP/Down.
We have Switches - ((C3750-IPBASE-M), Version 12.2(25)SEB4) & Routers - (C2900-UNIVERSALK9-M), Version 15.1(4)M3.
Thanks in Advance,
Best Regards,
Taufeeq.
I think the   following link is very helpful:
http://www.ciscozine.com/2010/12/17/send-email-from-your-router-using-eem/
6 Replies 6
You can use EEM scrip to achieve the same. Just check EEM scripting in the community directory for some examples.
Sathvik
thanx for the help wink
MickLu
The link has expired.
does anyone can help?
marce1000
  - In a more generic approach you should, for instance, also have a look at network management tools which can be configured to re-act on snmp traps  by using several methodologies such as e-mail alerts. An additional benefit is to                                            keep an overview on what is happening on the network.
 M.
