RIPV2 NOT SHOWING UP ON IP ROUTE
Hyn
I am having a problem where after I added the networks to RIPV2 and no auto-summary, the ip show route does not show R or RIP. Is there any thing that I missed out?
what router/L3 switch is this on ? If you are using Packet Tracer, I think it is a bug. I seldom get RIPv2 to work at all in PT. Better use EIGRP...
Hello
Are these networks you've added active on the rtrs as if they are not they wont be advertised.
Kind Regards
Paul
The original poster asks if he missed something. It is hard to answer that with out seeing the configuration. It might also be helpful to see output of show ip protocol.
Rick
