Empty Access group
reashad
Level 2
Level 2
Hi All,
what is the purpose of using a ACL that is not defined on a VLAN or an Interface?
interface Vlan50
ip address 10.200.96.1 255.255.255.0
ip access-group 130 in
"access-list 130" doesn't exist on rest of the config
Georg Pauwen
somebody probably forgot to remove it, or has put it in there for future use. An access-group without an existing access list to match has no effect, that is, all traffic is allowed.
If you are in charge of the network, I would remove the line as it can cause confusion.
Georg Pauwen
balaji.bandi
then that config is redundant and it not have any effect at all.
BB
Deepak Kumar
This seems a mistake and looking that the admin may forget to add or remove from the configuration. This is not doing anything and allowing everything.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
