enable do1q encap !!
sajiccie_220
Dear all,
We are trying to enable do1q encap on Fastethernet of 3460 Router
with
IOS c3640-is-mz.122-32.bin
interface FastEthernet0/1.1
encapsulation dot1Q 501
ip address 192.168.0.1 255.255.255.252
I put a PC with an IP 192.168.0.2 and connected on FastEthernet0/1.1 .but it's not pinging . We want to connect some
wireless customers on this Port .Wireless Provider needed to enable
dot1Q enacap on interface
Can anyone Can help with the configuration ?? .It's very urgent
Regds
Saji k.s
Network consultant
mattias.dewulf
Do you attach the pc directly to Fastethernet 0/1 with a crossover cable? That pc will only be able understand the packets from the native (untagged) vlan. vlan 501 packets will be tagged, and only understood by a dot1q trunk (on a switch for example), I think. Is there an ip on the physical Fastethernet 0/1 also?
