Enable log on 3825
ttran
Hi All,
What do I have to enable in order to see this on router 3825?
! Last configuration change at 21:30:36 Thu Mar 31 2005
! NVRAM config last updated at 21:30:50 Thu Mar 31 2005
TIA
--Tho Tran --
Richard Burts
What you need to get the time element in the configuration change is to have the time set in the router. You can do this with the clock set privilege level command. But depending on your router model, this may disappear with the next reboot of the router. A much better alternative is to run NTP on the router and have the router learn time from some source. This will assume that you always get the configuration change at ... messages.
Rick
Rick
