Subinterface routing on a 3825
wshall
using a 3825 with the advanced service image I'm trying to route between different subnets but have been unsuccessful. Does this setup look correct?
When I do a sh ip route I never see these route showup. I've tried turning on rip and I've tried static routing. Been beating my head against the wall trying to figure out the problem.
Any ideas on what I'm doing wrong?
Thanks wes
_________________________________
interface GigabitEthernet0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed 100
media-type rj45
negotiation auto
no mop enabled
interface GigabitEthernet0/0.104
encapsulation dot1Q 104
ip address yyy.xxx.104.1 255.255.254.0
no ip redirects
no ip unreachables
no ip proxy-arp
no snmp trap link-status
interface GigabitEthernet0/0.108
encapsulation dot1Q 108
ip address yyy.xxx.108.1 255.255.254.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet0/1
ip address yyy.xxx.100.1 255.255.252.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
media-type rj45
negotiation auto
no mop enabled
router rip
network yyy.xxx.0.0
Router#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
yyy.xxx.0.0/22 is subnetted, 1 subnets
C yyy.xxx.100.0 is directly connected, GigabitEthernet0/1
ashok_boin
Level 5
Level 5
Configuration looks ok. But, why the subnets for G0/0 subinterfaces are not showing up in the routing table as connected? Does the G0/0 interface showing UP?
Did you enable the trunking at switch end?
Regds..
-Ashok.
With best regards...
Ashok
