Enable ssh on a router!
nguyodan1
Community Member
Hi all, I just bought an additional router for my network and I'm in the process of setting it up.
I have however hit a snag with enabling ssh on the device. It is a cisco router 2811 running IOS 15.0 (refer below to my attempts)
test#sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 15.0(1)M6, RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 01-Jun-11 16:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
test#sh ip ssh
% Invalid input detected at '^' marker.
test#
test(config)#hostname test-router
test-router(config)#user
test-router(config)#username cisco priv
test-router(config)#username cisco privilege 15 pas
test-router(config)#username cisco privilege 15 password cisco
test-router(config)#ip domain
test-router(config)#ip domain-
test-router(config)#ip domain-n
test-router(config)#ip domain-name test.com
test-router(config)#crypto key generate rsa
test-router(config)#crypto key generate rsa  ?
% Unrecognized command
Kindly advice what i'm I doing doing wrong.
My older routers are comfortably running ssh.
Dan
bretthadden
Community Member
Hey Daniel,
You running IPBase IOS. Try upgrading to cryptographic cisco IOS. (ipservicesk version)
ENTERPRISE SERVICES        Service Contract Required
c2800nm-entservicesk9-mz.150-1.M6.bin
Release Date: 03/JUN/2011
Size: 54636.00 KB (55947260 bytes)
Minimum Memory:        DRAM:256MB        Flash:128MB
Cheers
Thanks Brett.
Dan
Let me know how things turn out.
Brett
