%SNMP-5-COLDSTART: SNMP agent on host ABCD_BCDA is undergoing a cold start
Hi All,
I came across a unique situation, where one of my WAN Router throws the captioned trap in my NMS.
"%SNMP-5-COLDSTART: SNMP agent on host  ABCD_BCDA is undergoing a cold start"
And event during the same time my router got rebooted and protocol connection reestablished,
Help me in getting this issue understandable.
Please share the reason too
I am using Cisco 2911(ISR G2 Rotuer)
Thanks & Regards
Karthikeyan P
mvsheik123
Level 7
Level 7
Do 'Sh ver' and see what caused the reboot. Make sure power cable is not loose. If everything looks fine, then you may want to contact TAC.
hth
MS
