Enabling ikev2 on cisco 4331
jomo frank
Hello Experts,
I have 4331 router but would like to use the vpn parameters found in IKEv2, and would welcome some guildance.
balaji.bandi
what kind of licese you have on that router ?
BB
hello bb
The information for your guildance.
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
The current throughput level is 500000 kbps
Smart Licensing Status: Smart Licensing is DISABLED
cisco ISR4431/K9 (1RU) processor with 1784726K/6147K bytes of memory.
Processor board ID FJC2330A1S8
6 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
6598655K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
Since you got the right License Security one you can use below Links for reference to build the tunnel
by the way, what is the other end device?
https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/117337-config-asa-router-00.html
https://www.omnisecu.com/ccna-security/how-to-configure-site-to-site-ikev2-ipsec-vpn-using-pre-shared-key-authentication.php
BB
