Enabling Traps on a BPX 8600
jrabener
Good Day,
I'm trying to figure out how to configure traps on a BPX 8600 ATM Switch.
I'm interested specifically in the following:
cpuUtilizationAboveNormal
Specific Trap 20021
This trap is generated whenever a BPX/IGX/IPX processor's CPU utilization is above the threshold.
and
memoryUtilizationAboveNormal
Specific Trap 20023
This trap is generated whenever a BPX/IGX/IPX processor's dynamic memory utilization exceeds a fixed threshold. The alarm is reported from the node based on existing statistics that are collected for profiling the performance of the node.
b.hsu
Level 5
Level 5
To configure traps we could use Cisco WAN Manager (CWM).Configure the network name and network CWM ID in the /usr/users/svplus/config/network.conf file. Refer URL
http://cisco.com/en/US/products/sw/netmgtsw/ps2340/products_technical_reference_chapter09186a00801ebb52.html#wp1000548
Brian,
Thanks for your reply. The link you provided should be helpful in configuring these traps.
Best Regards!
