Issues pinging - Small test network
danny9797
Hi everyone,
I have a small test network setup (virtual).
I'm having problems pinging Router 1 from Router 3. I can ping Router 3 from Router 1 fine. Both can ping Router 2 no problem.
Here is a brief summary on how everything is set:
ROUTER_1 - ROUTER_2 - 192.168.10.1
ROUTER_1 - PC1 - 192.168.20.1
ROUTER_2 - ROUTER_1 - 192.168.20.2
ROUTER_2 - PC2 - 192.168.30.1
ROUTER_2 - ROUTER_3 - 192.168.40.1
ROUTER_3 - ROUTER_2 - 192.168.40.2
ROUTER_3 - PC3 - 192.168.50.1
PC3 - FA0/0
ROUTER 3-2 - S0/0
ROUTER 2-3 - S0/1 (Clockrate set)
PC2 - FA0/0
ROUTER 2-1 - S0/0 (Clockrate set)
ROUTER 1-2 - S0/0
PC1 - FA0/0
Below is a screenshot:
[IMG]http://www.wholesaledropkit.com/boson.bmp[/IMG]
[IMG]http://www.wholesaledropkit.com/boson2.bmp[/IMG]
Any ideas?
bjw
Level 4
Level 4
Can you post the config of all 3 routers and the show ip route output of all 3 routers?
