Enabling Vlan Cause another to shutdown
johnroche_2
HI
I have a cat 2950 switch with 3 vlan LANs
Everytime i enable vlan 2, vlan 1 shutsdown. if I issue no shut on vlan 1, vlan 2 will shut
What am I doing wrong
7 Replies 7
spremkumar
Level 9
Level 9
Hi John
Cicso 2950 is a layer 2 Switch and you can have only one SVI interface configured under that with ip address assigned to it.
If you try to create one more SVI with ip address the existing will be shut automatically.
But you can create layer 2 vlans under the vlan database and assign a port to be a member of that particular vlan using switch port command under the interface.
regds
How can I tell the vlan its not an SVI
jolmo
Level 4
Level 4
Hi John
I think, first you should check your switch is in VTP server mode or VTP transparent mode. Then, try to configure VLANs in VLAN Configuration Mode ("vlan database" command).
By the way, how do you enable vlans?
Hope this helps
I dont use vlan database command
here is what i have
interface FastEthernet0/1
switchport trunk native vlan 2
switchport mode trunk
speed 100
duplex full
interface FastEthernet0/23
interface FastEthernet0/24
description *** Trunk to Computer Room ***
switchport trunk allowed vlan 1,2
speed 100
duplex full
interface FastEthernet0/25
interface FastEthernet0/26
interface Vlan1
ip address 192.168.100.101 255.255.255.0
no ip route-cache
interface Vlan2
ip address 10.15.15.101 255.0.0.0
no ip route-cache
shutdown
Hi John
As i have clearly mentioned in my earlier mail its not possible to have more than one SVI (VLAN) configured with ip address on your Cisco 2950 Switch.
You can make use of only one SVI (VLAN) with ip address configured.
If you want to have 2 different SVI (VLAN) interfaces with ip address configured you should look for a Layer 3 switch where in you can configure multiple SVIs based on your requirement.
regds
lgijssel
Level 9
Level 9
You are probably talking about interface vlan X. This is the management interface for the switch and you are allowed to have only one of those on a layer2 switch. The management interface is used to perform switch management (telnet, http) over the network.
This does not say anything about the capability to switch different vlans. Use the command: "sh vlan" or "sh int status" to see which vlans the switch is aware of and to which ports they are assigned.
Leo
pciaccio
Level 4
Level 4
For this type of switch you must keep VLAN 1 as management. If youtry to move it to another VLAN VLAN 1 will shut down. Keep VLAN 1 as management and move on with your configuration....
