11-13-2006 01:31 AM - edited 03-03-2019 02:41 PM
I would like to ask if anyone has experiences with using 8MB FLASH SIMM modules from 2600 series routers in the 2500 series. I have tried to find as much information as possible but the technical info about 2500 FLASH modules is very sparse.
I am trying to extend a few 2500 series routers with more FLASH and I have some 2600 series 8MB FLASH modules handy but I am not sure if they are usable in the 2500 series routers.
Any suggestion is appreciated!
Best regards,
Peter
Solved! Go to Solution.
11-13-2006 03:10 AM
Hello Peter,
unfortunately, the flash SIMMs from the 2600 are not compatible with, or usable in, the 2500 series routers.
Check these links for details:
8MB Cisco 2500 (old BIOS) Approved Flash SIMM (p/n MEM-1X8F)
http://www.memoryx.net/mem1x8f1.html
8MB Cisco 2600 Router Approved Flash Memory (p/n MEM2600-8FS=)
http://www.memoryx.net/mem26008f.html
HTH,
GP
11-13-2006 03:10 AM
Hello Peter,
HTH,
GP
11-14-2006 12:10 AM
Hello Georg,
Thank you very much for your reply.
With best regards,
Peter
