encapsulation dot1q is not working?, 2600 Cisco router
jesserc68
     I am trying to config a 2620 Cisco router to perform subintreface (F0/0.1) for Vlan Trunk Protocol, however when I try to configure the encapsulation dot1q, I continue to receive error massage with ^ symbol below the 'c' See below, the platform version is a 12.3(26) which should be acceptable to perform an (encapsulation dot1q). The Ethernet is a fast-Ethernet 10/100 port. I also try the ISL, I receive the same massage.
Can anyone suggest what could be the problem!!
Thank you all!!!!!
Router#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#int f0/0
Router(config-if)#no ip address
Router(config-if)#no shutdown
Router(config-if)#int f0/0.1
Router(config-subif)#encapsulation dot1q 1
^ % Invalid input detected at '^' marker. Router(config-subif)#
==================================================================================================== Router#show version
Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-I-M), Version 12.3(26), RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2008 by cisco Systems, Inc. Compiled Mon 17-Mar-08 15:23 by dchih ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1) Router uptime is 5 minutes System returned to ROM by power-on System image file is "flash:c2600-i-mz.123-26.bin" cisco 2620 (MPC860) processor (revision 0x600) with 28672K/4096K bytes of memory . Processor board ID JAD05440GAN (1508240486) M860 processor: part number 0, mask 49 Bridging software. X.25 software, Version 3.0.0. 1 FastEthernet/IEEE 802.3 interface(s) 1 Serial network interface(s) 32K bytes of non-volatile configuration memory. 8192K bytes of processor board System flash (Read/Write)
Router#
Router#sh flash
System flash directory:
File  Length  Name/status
1  7754580  c2600-i-mz.123-26.bin [7754644 bytes used, 633960 available, 8388604 total]
Router#
34 Replies 34
I just spoke with a friend and they are well to get the IOS C2600-is-mz.123-26.bin, once I implement the new IOS I will let you all know.
Jesse
May we know if C2600-is-mz.123-26.bin fixed the issue and allowed the router subinterface for encapsulation?
JB
So the problem is the IOS version ..!
I'm going to inform my IT group about it
Because we are going to make a lab with routers and switches
I found this post useful somehow
debnathgayatri
I have the same error on the cisco 2612 router, version is 12.1(19).
rythem007
hi guys,
good news
i solved this problem
it also work on ethernet port
i thought it will be issue of cisco ios version,so i tried many ios
apart from all i got this ios is working for me of cisco2611xm router
check yours.best of luck
Cisco iOS-c2600-is-mz.121-18.bin
my email is ridhammayani007@gmail.com
if you need IOS or further help contact me
