Encapsulation dot1q
ghtmoha153
I have router 2921 with 3 layer 3 interfaces i need to configure one of them as access interface encapsulation in bidirectional (not subinterface solutions)
9 Replies 9
Mark Elsen
 - The question is confusing , layer 3 interface, can not be access ports ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
My question is layer3  interface can encapsulation packets and send it out from router or no t
in the router and in SW must not use native vlan, native vlan is send untag frame
for config you need
in SW config trunk and allow vlan <vlan id>
and in Router config subinterface with encapsulation dot1q <vlan id>
In my case i want to configure two interfaces in same router one is physical and second one is subinterface with vlan 3090 in another physical interface and physical one i need connect it to end device
sorry can you more elaborate more?
router interface f0/0 without subinterface
router interface f0/1 with subinterface
and then what?
 So in R1 i configure bridge group (interface fa0/0 and fa0/1.3090)  fa0/0 is connected to switch 3750 with vlan 1
Fa0/1.3090 connect to sw 3750 with vlan 3090 i do ping between int vlan 3090 and int vlan 1 so no reply what can i do to connect vlan 1 and 3090
R1
bridge irb
bridge-group 1
interface FastEthernet2/0.999
encapsulation dot1Q 999
bridge-group 1
interface BVI1
ip address 10.0.0.10 255.255.255.0
bridge 1 protocol ieee
bridge 1 route ip
IOU1
interface Vlan1
ip address 10.0.0.1 255.255.255.0
no ip route-cache
ip default-gateway 10.0.0.10
IOU2
interface Vlan999
ip address 10.0.0.2 255.255.255.0
no ip route-cache
interface Ethernet2/0
switchport trunk allowed vlan 999
Hello
Yes it can.
The physical port of the interface will connect to the switch at layer 2 and then the logical sub-interfaces provids the Layer 3 addressing that relates to the specific vlan ids using dot1q trunking.
By default if you use the parent physical interface as L3 also then this is the native vlan 1
example:
int x/x
description vlan 1
ip address 10.1.1.1 255.255.255.0
or
int x/x
int x/x.1
description vlan 1
encapsulation dot1q 1 native
int x/x.2
description vlan 2
encapsulation dot1q 2
ip address 10.1.2.1 255.255.255.0
int x/x.3
description vlan 3
encapsulation dot1q 3
ip address 10.1.3.1 255.255.255.0
Kind Regards
Paul
