Entending Layer 2 across a Layer 3
brianalster
I am needing to extend a layer 2 vlan thru an ISR router.  The vlan is configured as two dot1Q sub interfaces (G0/0/1.X and G0/0/2.X).  On my ASR's I can configure a "connect" command and link them together that way, but on the ISR, my "connect" options are limited to "Dialer and MFR".
I'm running universalk9.03.16.10.S.115-3 code level on my ISR.  Is the extended "connect" options available on a different/newer code level or is the ISR platform limited?
balaji.bandi
Can you post show version and show license what you have :
you need advanced feature license to use  "L2VPN Pseudowire Switching"
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/mp_l2_vpns/configuration/xe-16/mp-l2-vpns-xe-16-book/l2vpn-pseudowire-switching.html
BB
MMC-Dar-Edge-ISR#sh ver
Cisco IOS XE Software, Version 03.16.10.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S10, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Fri 04-Oct-19 06:36 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2019 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
MMC-Dar-Edge-ISR uptime is 20 hours, 44 minutes
Uptime for this control processor is 20 hours, 45 minutes
System returned to ROM by reload at 10:41:11 EDT Wed Sep 2 2020
System restarted at 16:06:33 EDT Wed Sep 2 2020
System image file is "bootflash:isr4300-universalk9.03.16.10.S.155-3.S10-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4351/K9 (2RU) processor with 7791931K/6147K bytes of memory.
Processor board ID FLXXXXXXXX
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16777216K bytes of physical memory.
14659583K bytes of flash memory at bootflash:.
Index 1 Feature: appxk9
Period left: Not Activated
Index 2 Feature: uck9
Index 3 Feature: securityk9
Period left: Life time
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
Index 8 Feature: hseck9
Index 9 Feature: throughput
Index 10 Feature: internal_service
I'm just trying to cross a single router.  The data is coming in on one dot1q sub-interface and I need it to go out a different dot1q sub-interface.  I am not trying to OTV or anything similar.
I tried to create a "bridge interface/group/bvi" but I wasn't getting any traction in that direction as I wasn't sure how to apply it to a sub-interface.
balaji.bandi
Thanks for the information, Do you have hgh level diagram also, please provide relavant configuration to understand better.,
Are you looking BVI ? or Looking "L2VPN Pseudowire Switching" ?
BB
