Error enabling PPPoE
Marcio Souza
Hi!
I'm trying to configure a Cisco 1841 router to use PPPoE with ADSL, but when I try to enable PPPoE on fa0/0 I get the following error:
Router(config)#int fa0/0
Router(config-if)#no ip address
Router(config-if)#pppoe enable
PPPoE create bba subblock failed
This is a new router never used and I'm doing the first configuration on it. I have done the dialer configuration, but I have stopped on the above error and I can't finish the configuration.
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
archive
log config
  hidekeys
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 10
ppp authentication pap callin
ppp pap sent-username XXXXXXXXXXXX password 0 XXXXXXXXXXXX
ppp ipcp route default
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
I need some help, because I googoled the above error and I have found nothing how to solve it.
Marcio
6 Replies 6
Hello
Ethernet interface
Int fa0/1
descritption Lan Interface
ip address 10.10.10.1 255.255.255.0 (rfc 1918 addressing )
io nat inside
no shut
Int fa0/0
descritption DSL Interface
no ip address
ppoe enable
ppoe-client dial-pool-number 1
ip tcp adjust-mss 1452
no shut
interface Dialer1
ip mtu 1492
encapsulation ppp
dialer pool 1
ppp chap sent-username USERNAME password P@ssw0rd (this is the password that ISP gave it  to you
ppp chap hostname HOSTNAME (This is the username that ISP gave it to you)
ip nat outside
no shut
p dhcp excluded-address 10.10.10.1
ip dhcp pool DHCP
network 10.10.10.0 /24
dns-server Primary DNS IP address Secondary DNS IP address (obtained from your ISP)
default-router 10.10.10.1
import all
i
ip access-list extended LAN_IP_Range
100 permit ip 10.10.10.0.0 0.0.0.255 any
ip nat inside source list LAN_IP_Range interface dialer 1 overload
ATM interfaces  ( same as above but instead of fa0/0 use the ATM interface
vpdn enable
vpdn-group ppoe
request-dialin
protocol pppoe
exit
interface ATM 0
description DSL interface
no ip address
dsl operating-mode auto
pvc x/x
no shutdown
pppoe-client dial-pool-number 1
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Hi Paul,
I tryed to configure the router as you have suggested but the same error appear every time I try to enable pppoe in any of the FastEthernet Interfaces, as following:
Int fa0/0
no ip address
ppoe enable
Another issue is when I tryed to configure "
USERNAME
password
P@ssw0rd (this is the password that ISP gave it  to you"
In this case I got the following error:
Router(config)#int Dialer1
Router(config-if)#ip address negotiated
Router(config-if)#ip mtu 1492
Router(config-if)#encapsulation ppp
Router(config-if)#dialer pool 1
Router(config-if)#ppp chap sent-username XXXXXXXXXXX password XXXXXX
% Invalid input detected at '^' marker.
No matter how I try to do this I get the same error.
Marcio
interface Dialer1
description ADSL WAN Dialer$FW_OUTSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
ip virtual-reassembly
zone-member security out-zone
encapsulation ppp
ip route-cache flow
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname .....................................
ppp chap password 7 .............................
ppp ipcp dns request
description ADSL WAN Interface
pppoe enable group global
no cdp enable
Hello
Not sure on this can ypu post output
Show version
Res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Hi Paul,
I have copied default configuration from flash to startup-config and tryed again. Despite that, I got the same error again, but instead of stop doing the configuration I have continued.
At the end the connection has been estabilished and all the users inside the Lan network are now reaching external sites pages.
Marcio
Hello
Thanks for the feedback - unusual issue but glad to hear its now working
Can you confirm or post what configuration you used for future reference
Res
Paul
Kind Regards
Paul
