error in ip accounting output
rakeshpra
While issuing the command “show ip accounting” on Cisco 10720 router the output is empty.
Command used for enable on  serial intyerface:-
router(config)#int serial 0/0
router(config-if)#ip accounting output-packets
router(config-if)#exit
But while input below command:-
Router#sh ip accounting
   Source           Destination              Packets               Bytes
Accounting data age is 03:08
Please suggest on this.
rakeshpra
we did not find any output for command router#show ip accounting output-packet
regards,
Rakesh
hi,
can you try on the LAN interface?
I have already checked this on fastethernet port:-
Int fa2/12
But output is same:-
Accounting data age is 03:01
