error message 892w
TimMees60387
I have a problem with my cisco 892W always get this message
% Error opening tftp: //255.255.255.255/network-confg (Timed out)
% Error opening tftp: //255.255.255.255/cisconet.cfg (Timed out)
% Error opening tftp: //255.255.255.255/r2-confg (Timed out)
12 Replies 12
Giuseppe Larosa
Hello @TimMees60387 ,
use
show version
to check the value of the configuration register.
You may have set a value that causes the router to look for a configuration file to be loaded via TFTP the error message is about this and uses the broadcast address to look for a TFTP server on the local subnet.
Feel free to post your show version .
Hope to help
Giuseppe
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.8(3)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Thu 28-Mar-19 20:26 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB3, RELEASE SOFTWARE (fc1)
R2 uptime is 2 hours, 8 minutes
System returned to ROM by reload at 14:05:10 UTC Mon Jun 1 2020
System restarted at 14:06:13 UTC Mon Jun 1 2020
System image file is "flash:c890-universalk9-mz.158-3.M2.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
we need to see the lines about the configuration register you have not reported them
Hope to help
Giuseppe
R2 uptime is 4 hours, 4 minutes
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 892 (MPC8300) processor (revision 1.0) with 472064K/52224K bytes of memory.
Processor board ID FCZ1448C37B
9 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 ISDN Basic Rate interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Embedded AP (s)
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO892W-AGN-E-K9    FCZ1448C37B
License Information for 'c890'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
the configuration register value is the default one
see
https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/50421-config-register-use.html
Please copy  in a txt file the configuration file of your router and then put it in an attachment in a new post.
Hope to help
Giuseppe
Seeing the config would be very helpful. In particular I believe that we would be looking to see if the config contains any of these commands:
service config
boot network
boot host
Rick
this is the running config
Building configuration...
Current configuration : 6343 bytes
! Last configuration change at 13:02:48 UTC Tue Jun 9 2020
! NVRAM config last updated at 12:59:29 UTC Tue Jun 9 2020
version 15.8
service config
service password-encryption
hostname R2
boot-start-marker
boot system flash:c890-universalk9-mz.158-3.M2.bin
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login authen local
aaa authorization network author local
aaa session-id common
memory-size iomem 10
clock timezone UTC 1 0
clock summer-time UTC recurring
clock calendar-valid
service-module wlan-ap 0 bootimage autonomous
crypto pki trustpoint TP-self-signed-3945582034
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3945582034
 revocation-check none
 rsakeypair TP-self-signed-3945582034
crypto pki certificate chain TP-self-signed-3945582034
 certificate self-signed 01
  30820248 308201B1 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393435 35383230 3334301E 170D3131 31323235 32333439
  33375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39343535
  38323033 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100900D 6293E313 40744659 1E2A4047 E9844B53 240B241D 711B5B64 E75F2063
  2D6CDE1B 52A3F448 BFEC9B67 16816048 04DBBD55 85235244 048CC4C4 DEDAA702
  9954D740 D50B2ED8 3DF3F681 A5553D5B AEA90921 FB6C2757 C23B12D1 B8121A23
  4B752336 A329E1A8 7E74AB8F 043D73AE D41FE2CA 1B3A238F 9071779C EF2B3A37
  E2F70203 010001A3 70306E30 0F060355 1D130101 FF040530 030101FF 301B0603
  551D1104 14301282 1052322E 63757273 6973742E 6C6F6361 6C301F06 03551D23
  04183016 80144A5C 914FA99D 03D1876D E957BEED 699CB046 CB05301D 0603551D
  0E041604 144A5C91 4FA99D03 D1876DE9 57BEED69 9CB046CB 05300D06 092A8648
  86F70D01 01040500 03818100 0A3C1966 428C49FA 69425B6A E3A1E8F6 4C5E1D7A
  59C36593 AB0EDA96 98BB8892 4B69790E BA1315B1 66F533C0 75E466CC A97CF517
  5C1F08FE 04BED2E9 33A2E41E 6CB639DA 4822809D AEA36F53 FCE92654 162C6A86
  E0717A9E DB7990E8 08B8AC7F F77DD4CA B500FD93 C0C4E7AE 62985FF0 64773971
  EADB6223 C6DA1122 9C1C4415
        quit
ip dhcp pool Wired-CISCO892W_R2_100Mbps_LAN_IPV4_Home
 import all
 network 10.20.10.0 255.255.255.0
 default-router 10.20.10.1
 netbios-name-server 10.20.10.1
 dns-server 8.8.8.8 8.8.4.4
 domain-name R2
 lease infinite
ip dhcp pool Wired-CISCO892W_R2_100Mbps_LAN_IPV4_Private
 import all
 network 10.20.20.0 255.255.255.0
 default-router 10.20.20.0
 netbios-name-server 10.20.20.1
 dns-server 10.20.20.1
 lease infinite
ip domain list telenet.be
ip domain name cursist.local
ip name-server 195.130.131.4
ip name-server 195.130.130.4
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip dhcp-server 195.130.137.3
ip dhcp-client update dns
ip cef
ipv6 unicast-routing
ipv6 cef
ipv6 multicast-routing
license udi pid CISCO892W-AGN-E-K9 sn FCZ1448C37B
username Tim privilege 15 secret 5 $1$GkFn$iyyJCTS7LYVwM102IYpKu1
redundancy
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 no ip address
interface FastEthernet7
 no ip address
interface FastEthernet8
 ip address 84.73.95.68 255.255.248.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 ipv6 address dhcp rapid-commit
 ipv6 enable
 ipv6 nat
interface GigabitEthernet0
 ip address dhcp client-id GigabitEthernet0
 ip nat outside
 duplex auto
 speed auto
 ipv6 enable
 ipv6 nat
interface wlan-ap0
 description Service module interface to manage the embedded AP
 ip unnumbered Vlan1
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
 switchport mode trunk
 no ip address
interface Vlan1
 description Wired CISCO892W_R1_LAN_100Mbps
 ip address 10.20.10.1 255.255.255.0
 ip nat inside
 ip tcp adjust-mss 1452
 ipv6 enable
 ipv6 nat
interface Vlan2
 ip address 10.20.20.1 255.255.255.0
 ip nat inside
 ipv6 enable
 ipv6 nat
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list ACLG_IPV4 interface GigabitEthernet0 overload
ip nat inside source static tcp 10.20.10.1 23 interface GigabitEthernet0 5000
ip nat inside source static tcp 10.20.10.1 513 interface GigabitEthernet0 6000
ip nat inside source static tcp 10.20.10.1 22 interface GigabitEthernet0 8000
ip nat inside source static tcp 10.20.20.1 23 interface GigabitEthernet0 9000
ip nat inside source list ACLG_IPV6 interface GigabitEthernet0 overload
ip ssh rsa keypair-name R2.local
ip access-list extended ACLF_IPV4
 permit ip 10.11.11.0 0.0.0.255 any
 permit ip 10.20.10.0 0.0.0.255 any
 permit tcp 10.20.10.0 0.0.0.255 any
ip access-list extended ACLG_IPV4
ipv6 ioam timestamp
control-plane
bridge 1 protocol ieee
bridge 2 protocol ieee
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
alias exec dot11radio service-module wlan-ap 0 session
line con 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input telnet ssh
 transport output pad telnet rlogin udptn ssh
line aux 0
line vty 0 4
 privilege level 15
 transport input telnet rlogin ssh
line vty 5 15
 privilege level 15
scheduler max-task-time 5000
ntp update-calendar
ntp server 65.55.21.16
end
try and globally configure:
no service config
Jun  9 12:14:44.083: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg
have you removed the command
service config as suggested by @Georg Pauwen and before by @Richard Burts ?
conf t
no service config
end
wr mem
Note:
the effect may not be immediate you may need to wait few minutes.
Hope to help
Giuseppe
Deepak Kumar
Run the below commands:
conf t
no service config
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thanks for posting the configuration. It confirms that you do have service config in the configuration. This is the source of the error messages. And removing that command will be the way to stop the error messages.
Rick
