Error trying to TFTP to a server
burleyman
Level 8
Level 8
I am getting the below error when I try to TFTP to a server in our domain. Any ideas. I checked the permissions on the target directory and it is good, in fact I opened it wide open to test and get the same error. I can TFTP to my laptop fine. The servers are domain controllers running windows 2003.
Switch#copy bootflash: tftp:
Source filename []? cat4000-i9s-mz.122-25.EWA4.bin
Address or name of remote host []? 10.89.3.31
TFTP: error code 2 received - Access violation
%Error opening tftp://10.89.3.31/cat4000-i9s-mz.122-25.EWA4.bin (Permission denied)
Mike
8 Replies 8
Mark Yeates
Level 7
Level 7
Mike,
Is there any chance of any security software on your server? Don't forget Windows 2003 does have
Windows firewall. Also ensure you have Write permissions on the TFTP directory on the TFTP server.
HTH,
Mark
I thought of that.....it is disabled. I don't see anything in the event logs as well.
The reason TFTP is on the doamin controllers is it is needed for RIS.
Mike
Which TFTP server are you running?
Jon Marshall
Mike
Couple of things
1) Are you sure that there is no subdirectory under 10.89.3.31 that you should be including in your tftp string
2) What is the tftp server you are running and what account is it running as ?
Jon
Mike
Also be aware that in some implementations of the TFTP server, the file must already exist in the directory (though that is more typically *nix than Windows).
Also are you sure that the TFTP service is running?
Rick
Rick
Service is running. It is running on a domain controller for RIS installs. I have done this before...maybe last year was the last time. The default location for this is the e:\remoteinstall I made the permissions on it everyone full just to test and still no luck.
Mike
I have traced it back to an issue on the server as I can do this to my laptop. Thanks everyone for your help.
Mike
ken.martinson1
This worked for me:
sudo apt-get install xinetd tftpd tftp
# nano /etc/xinetd.d/tftp , enter the following:
service tftp
protocol = udp
port = 69
socket_type = dgram
wait = yes
user = nobody
server = /usr/sbin/in.tftpd
server_args = /tftpboot
disable = no
sudo mkdir /tftpboot
sudo chmod -R 777 /tftpboot
sudo chown -R nobody /tftpboot
sudo service xinetd restart
on linux:
# nano /etc/selinux/config , enter the following:
SELINUX=disabled
SELINUXTYPE=targeted
SETLOCALDEFS=0
# flush the iptables to disable them.
iptables -F
# create the files and put "chmod 777" on them.
cd /tftpboot
touch startup-config
chmod 777 startup-config
touch c2950-i6q4l2-mz.121-19.EA1c.bin
chmod 777 c2950-i6q4l2-mz.121-19.EA1c.bin
# on the router, go into "en" mode.
# backup the startup-config file
copy nvram:startup-config tftp:
10.10.10.20   (the ip of the linux box)
startup-config (the file on the linux box)
# backup the IOS file
copy c2950-i6q4l2-mz.121-19.EA1c.bin tftp:
c2950-i6q4l2-mz.121-19.EA1c.bin (the file on the linux box)  (note: "l" not "1")
