Error when upgrading Cisco ASR920 from XE 16.9.3 to XE 16.9.7
jules0
Hello all
I have a number of Cisco ASR920 Routers (ASR-920-12CZ-D) that need upgrading from XE 16.9.3 to XE 16.9.7 (16.9.7 is the customer request) I have downloaded the .BIN file from Cisco and followed the below process:
Router#copy usb0:asr920-universalk9_npe.16.09.07.SPA.bin bootflash:
Router# conf t
Router (config)# no boot system
Router (config)# boot system bootflash:asr920-universalk9_npe.16.09.07.SPA.bin
Router (config)# end
Router# write
Router# reload
However upon reloading it detects and error with the XE 16.9.7 file and proceeds to boot with the XE 16.9.3 file
Can you advise what could be wrong please? I'm only upgrading from a couple of sub-versions!
6 Replies 6
Leo Laohoo
Do the following:
conf t
 NO boot system bootflash:asr920-universalk9_npe.16.09.07.SPA.bin
 boot system flash bootflash:asr920-universalk9_npe.16.09.07.SPA.bin
end
wr
Refer to:  Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
I think he is face mismatch between the ROMMON ver. and IOS XE ver.
For now, I am going with the incorrect boot variable statement because that is the only useable information provided.
And I doubt it is the ROMMON version mismatch since the router is upgrading from 16.9.3 to 16.9.7.  Both old and new firmware version are from the same train.
I moved your post to a more suitable location in the community as it’s not related to anything in the Collaboration area.
Response Signature
