Error while giving level 7 password
ashley9march
Community Member
While creating a user and giving a level 7 password on the cisco 3745 Router, its showing the following error:
Invalid encrypted password: cisco
But if I give it level 0 password which is unencrypted level, it takes it successfully. "service password-encryption" is also enabled.
Router(config)#username cisco password 7 cisco
regds
Ashish
HCL Infinet Ltd
India
mhussein
Level 9
Level 9
If you are adding a new user, you should use username cisco password 0 cisco
and it will be encrypted:
router(config)#username cisco password 0 cisco
router(config)#do sho run | i username cisco
username cisco password 7 045802150C2E
Now you can copy the encrypted password (045802150C2E) and configure it for the same or any other user on any router with username cisco password 7 045802150C2E. This feature allows for username portability.
Note that, the encrypted password can easily be cracked:
http://www.kazmier.com/computer/cisco-noswing.html
For a stronger password use username cisco secret 0 cisco
Reference:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fsecur_r/fothercr/srfpass.htm#wp1030793
Mustafa
Though it has solved my problem to some extent but the mystery is still unsolved completely because once I use the 'do' command, I can create more then one user with level 7 password at the same time without using the 'do' command again for each user. I know this 'do' command is used to run exec level commands in global conf mode but Is the same command is any type of service also?
Thanx for your reply.
Sorry, I jammed all commands in 2 lines. You are right, the "do" command is just a convenient way of using exec commands from the config mode, it has no significance here.
What I meant to say is, when using "username cisco password 0 ..." the IOS is expecting you to type a clear text password. After that the IOS encrypts the password because "service password-encryption" is enabled:
router(config)#exit
router#show running-config
Does that make sense?
Georg Pauwen
you cannot enter a level 7 password in cleartext, level 7 expects an encrypted string. In order to enter ´cisco´ as an encrypted string, you first have to find out what the encrypted string looks like, once you know that, you can enter that string:
enable password 7 110A101614D
Try the following in order to see how it works:
Type ´enable password 0 cisco´ and then enable ´service password-encryption´. Write down the encrypted string you see in your configuration. Then reverse what you just did, that is, type ´no service password-encryption´ and ´no enable password 0 cisco´. Then, type ´enable password 7´ followed by the encrypted string you wrote down...
HTH,
GP
