Error with "dir flash:"
cisco24x7
Level 6
Level 6
Anyone knows why I am getting this "dir flash" error output. See below. I have no issues with others 2851 routers running the exact same IOS image:
2851#show flash:
-#- --length-- -----date/time------ path
1 1623191 Jul 10 2007 21:25:58 +00:00 C2800NM_RM2.srec.124-13r.T5
3 38444260 Jul 30 2007 20:19:58 +00:00 c2800nm-advipservicesk9-mz.124-16.bin
5 51432612 May 8 2009 05:10:18 +00:00 c2800nm-advipservicesk9-mz.124-15.T9.bin
125165568 bytes available (131342336 bytes used)
C2851#
C2851#dir flash:
Directory of flash:/
%Error calling getdents for flash:/ (File not found in Inode table)
256507904 bytes total (125165568 bytes free)
C2851#
C2851#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(16), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 20-Jun-07 07:19 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T5, RELEASE SOFTWARE (fc1)
C2851 uptime is 27 weeks, 6 days, 8 hours, 13 minutes
System restarted at 05:54:21 gmt Sat Oct 25 2008
System image file is "flash:c2800nm-advipservicesk9-mz.124-16.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2851 (revision 53.51) with 512000K/12288K bytes of memory.
Processor board ID FTX1033A0LH
2 Gigabit Ethernet interfaces
1 Serial interface
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
C2851#
Laurent Aubert
Can you format the flash and see if it resolves the issue ?
Laurent.
