Error with WIC-1DSU-T1-V2
ajohnson
I am trying to install this WIC into a 2811 without luck. I have received two of these WIC cards from vendor with no success. Both times I get the following output from "show diag" and messages on console.
WIC Slot 3:
Unknown WAN daughter card
Hardware revision 0.0 Board revision 70
Serial number 0 Part number 00-0000-00
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 0
EEPROM contents (hex):
0x20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Bad Hardware in bay/slot/sub_slot = 0/3/-1
Unknown WIC in slot(0/3), wic card has an unknown id of 0x0
vwic_port_count: unknown vwic - 0
vwic_card_type: unknown vwic - 0
I have tried different slots on the 2811 without a change. First on IOS 12.3(8)T8 and also have tried on 12.3(11)T. No change.
Any ideas? Bad lot of WIC's from vendor?
Thanks.
thisisshanky
Level 11
Level 11
Its possible the h/w is bad, can you make sure the cards are seated properly in the slot ? Can you type a sh version ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
I guess it is possible that the vendor has a bad lot of WICs since this is the 2nd one.
Here is "show ver"
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.3(11)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Sat 18-Sep-04 12:53 by eaarmas
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Router uptime is 0 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.123-11.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FTX0926A1PB
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
I have tried different slots. The WIC's are very snug compared to others that I have installed in the past. They dont feel like they fit right to me.
