ES+ port configured as regular switchport
Robert Saurer
Will PFC QoS apply if an ES+ port is configured as regular switchport?
I saw this in real life and I'm looking for arguments against it.
mls qos
int g4/1                    ! in slot 1 is an ES+ linecard
switchport
switchport mode access
switchport access vlan 10
mls qos vlan-based
int g5/1                    ! in slot 5 is the RSP720
switchport
mls qos vlan-based
interface vlan10
ip address 10.0.0.1 255.255.255.0
service-policy input FOO
class-map BAR
match any            ! according to PFC QoS docs "match any" is not supported at all
policy-map FOO
class-map BAR
  set ip dscp cs1
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
I'm not positive, but I thought ES+ ports had more extensive QoS, supported on the card, than typical LAN type ports.
