Routing issue - site to site
Dear all,
Based on diagram attach, how do i route the Staff PC to access the Server.
Currently the Staff can only ping up to the outside interface of ASA site A( 60.a.a.54)
What is the command to route the Staff (192.168.5.33) to Server (192.168.0.150).
2 Accepted Solutions
IcebergTitanic
Yep, I think what you want is to make your routers completely transparent. Essentially doing nothing but turning your WAN (PPP) connection into an ethernet connection for the ASA.
Set up your VPN tunnel on the ASA, and use that to route your LAN traffic. Should work like a dream, then.
Post back if you need help configuring the ASAs...
There are 6 Main Mode messages. Each message has a specific purpose. The status state of MM_WAIT_MSG2 could mean:
1. you are using Main Mode
2. You are waiting
3. You are waiting on Message 2 of Main mode
Message 1 is used to send your phase 1 proposals. Message 2 is sent by the remote end accepting the SA.
So the question is "Why is my ASA waiting on MSG 2?"
This could be for several reasons.
1. Maybe your packet is being dropped somewhere
2. Maybe there is a problem in the path causing the drop (High BW Utilization, bad circuit etc...)
3. The remote device believes it does not have to renogotiate or the SA is stuck for some reason
What you could try is configuring dead peer detection. This would allow the ASA to detect if the peer is gone, tear down the tunnel and allow for the new SA to be established when the peer is available.
The command below should help:
isakmp keepalive xxx
Place this on both devices then clear the isakmp SAs on both ends.
Please rate the helpful posts.
Naidu.
18 Replies 18
Ivan Krimmel
Level 7
Level 7
Hi Mohd,
can Server access the outside world? i.e. I am trying to understand, whether there're any issues with Server TCP/IP settings. If yes, then we'd need to check ASA'a settings. What do you use in there - NAT? Identity NAT? Paste the relevant config here. Also, is that only ICMP not working, I guess the purpose of this setup for the Client to access something else on the Server. Check the ACL applied to the outbound interface on the ASA.
HTH,
Ivan.
Hi Ivan,
The server can go Internet as normal.
Staff need to see Server for database purpose.
I attached the ASA conf below.
Site A - ASA 5510
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.08.11 11:01:19 =~=~=~=~=~=~=~=~=~=~=~=
ASA Version 8.0(3)
hostname
domain-name default.domain.invalid
enable password ym1CwmrLnc/fndsu encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 60.a.a.54 255.255.255.252
interface Ethernet0/1
no nameif
no security-level
no ip address
interface Ethernet0/1.1
vlan 10
nameif Inside
security-level 80
ip address 192.168.0.1 255.255.255.0
interface Ethernet0/1.2
vlan 20
nameif visitor
security-level 100
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group DefaultDNS
access-list 100 extended permit icmp any any
access-list 100 extended permit tcp any any
access-list 100 extended permit ip any any
access-list 101 extended permit icmp any any
access-list 101 extended permit tcp any any eq 2828
access-list 101 extended permit tcp any host 192.168.0.254 eq 2255
pager lines 24
mtu outside 1500
mtu Inside 1500
mtu visitor 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any Inside
icmp permit any visitor
asdm image disk0:/asdm-507.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (Inside) 1 192.168.0.0 255.255.255.0
nat (visitor) 1 192.168.1.0 255.255.255.0
static (Inside,outside) tcp interface 2828 192.168.0.254 telnet netmask 255.255.255.255
access-group 101 in interface outside
access-group 100 in interface Inside
access-group 100 in interface visitor
route outside 0.0.0.0 0.0.0.0 60.a.a.53 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:30:00 absolute uauth 0:30:00 inactivity
dynamic-access-policy-record DfltAccessPolicy
aaa authentication include tcp/0 Inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 0.0.0.0 0.0.0.0 Inside
telnet 192.168.4.0 255.255.255.0 Inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 Inside
ssh timeout 5
console timeout 0
dhcpd dns 202.188.0.133 202.188.5.1
dhcpd address 192.168.0.2-192.168.0.253 Inside
dhcpd enable Inside
dhcpd address 192.168.1.2-192.168.1.253 visitor
dhcpd enable visitor
threat-detection basic-threat
threat-detection statistics access-list
username admin password bOnxO8/ZA7i5hOxq encrypted
username kpmsb password /LTd0pEXjM6Ht1Sp encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:809895a4506cb7e47a57552c4a0e0a0f
: end
Site B - ASA 5510
ASA Version 7.0(8)
hostname ASA
passwd ym1CwmrLnc/fndsu encrypted
names
dns-guard
nameif outside
security-level 0
ip address 218.b.b.234 255.255.255.252
no nameif
no security-level
no ip address
vlan 10
nameif office
security-level 50
ip address 192.168.5.1 255.255.255.0
vlan 20
nameif visitor
security-level 50
ip address 192.168.6.1 255.255.255.0
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
clock timezone MYT 8
access-list 100 extended permit tcp any host 218.111.42.234 eq 2828
access-list 101 extended permit ip any any
access-list 102 extended deny ip any 192.168.0.0 255.255.255.0
access-list 102 extended permit icmp any any
access-list 102 extended permit tcp any any
access-list 102 extended permit ip any any
pager lines 24
logging enable
logging buffer-size 1000000
logging buffered debugging
logging asdm informational
mtu outside 1500
mtu office 1500
mtu visitor 1500
mtu management 1500
icmp permit any office
asdm image disk0:/asdm-508.bin
arp timeout 14400
nat (office) 1 192.168.5.0 255.255.255.0
nat (visitor) 1 192.168.6.0 255.255.255.0
static (office,outside) tcp interface 2828 192.168.5.254 telnet netmask 255.255.255.255
access-group 100 in interface outside
access-group 101 in interface office
access-group 102 in interface visitor
route outside 0.0.0.0 0.0.0.0 218.b.b.233 1
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 3:00:00 absolute uauth 3:00:00 inactivity
username test password P4ttSyrm33SV8TYp encrypted privilege 15
username admin password eY/fQXw7Ure8Qrz7 encrypted privilege 0
aaa authentication include tcp/0 visitor 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 LOCAL
aaa authentication include http office 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 LOCAL
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 outside
http 192.168.1.0 255.255.255.0 management
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
telnet 0.0.0.0 0.0.0.0 office
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 office
ssh timeout 5
console timeout 0
dhcpd address 192.168.5.2-192.168.5.253 office
dhcpd address 192.168.6.2-192.168.6.253 visitor
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd dns 202.188.0.133 202.188.1.5
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable office
dhcpd enable management
  inspect dns maximum-length 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
Cryptochecksum:2ec9bdf0050db34b872292128bf29818
: end
Anyone can help me on this? Why the staff can't access server
Mohd -
Looking at your ASA configurations, you do not have site-to-site VPN configured.  You diagram shows that you do.  In any case, in order for both sites to communicate, one method is to used VPN.  Here's a link on setup site-to-site VPN for ASA: http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080950890.shtml.
Hope this helps.
Since staff can access outside interface of ASA in site A, the non-existence of a VPN is not a case here.
Mohd, I am still looking into this, couldn't spot the issue yet though.
Ivan.
Ivan - Just my .02...  If Staff PC's can PING the outside of the firewall on Site A, so can anyone else since it's a public IP.  The original question was how to route the staff PC (Site B) to the server (Site A).  Unless he is doing one-to-one static NAT (which doesn't seem like it based on the ASA config), I think VPN (remote access or lan-to-lan) is the best solution in this case.
Regards.
I agree, it is because they have icmp permit any outside , but since staff can access it, it means the routing is correct, and we only need to let the traffic in, which is being controlled by ASA in site A.
Mohd, is server able to reach the outside interface of ASA at site B? perhaps, to reach the inside network behind ASA B?
Ivan.
IcebergTitanic
See, the problem is that the ASA doesn't want to route a private IP address over the internet. Private IP addresses were made specifically so that people could have lots of local devices and not all have to have specific exterior internet addresses, which is how they were set up originally.
Your diagram does show an IPSEC vpn somewhere, but your configs do not reflect any kind of VPN setup in them. You're missing a lot of configuration to establish a site to site VPN, presuming you're trying to do it over the ASAs.
The ASA's are showing an outside IP address on them. They won't want to route private IP ranges over an internet connection.
Right now, I suspect your routing looks like this:
Workstation traffic leaves, headed for a different network. (192.168.0.x)
The ASA gets it, has no specific route or connected interface that matches the destination network.
ASA throws the traffic out, because it's not going to route LAN traffic out over a WAN connection, because that's just silly.
You really need to have a VPN if you want to route out to the other side using a private IP range.
If you're really set on doing it without a VPN, then you need a local DNS server that tells your local workstations the external IP address of the destination server, rather than trying to connect to its private IP address.
Dear all,
Thanks for the reply.
I need to mention here that the VPN is establish using the Cisco 887.
That why i ask the question because, i just stuck at host to host issue.
But severel people said that the VPN should be done on the ASA rather that at the 887.
Anyway, here i attach the 887 config,
Like "jliscano" said, is the one to one static NAT posible. ( for me to route both site)
or should I do vpn at ASA.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.09.27 16:10:56 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 6394 bytes
! Last configuration change at 08:13:54 UTC Tue Sep 27 2011 by nec
! NVRAM config last updated at 08:12:56 UTC Tue Sep 27 2011 by nec
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service sequence-numbers
hostname kewpie-mlk
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 $1$zrgO$UTdQAb.LzJq9y7n22R/Th/
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-2510246803
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2510246803
revocation-check none
rsakeypair TP-self-signed-2510246803
crypto pki certificate chain TP-self-signed-2510246803
certificate self-signed 01
ip source-route
ip dhcp pool ccp-pool1
   import all
   network 60.a.a.0 255.255.255.0
   dns-server 202.188.0.133 8.8.8.8
   default-router 60.a.a.53
ip cef
ip domain name yourdomain.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
license udi pid CISCO887-K9 sn FGL152827A7
username nec privilege 15 secret 5 $1$ludy$bhR/Z7LEe3.L4d.ZK/aT30
username test secret 5 $1$1WcH$zyEruqlm/ui/XFTscMBvD.
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key kewpievpn address 218.b.b.233
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to218.b.b.233
set peer 218.b.b.233
set transform-set ESP-3DES-SHA
match address 100
interface BRI0
no ip address
ip flow ingress
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
ip flow ingress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
ip flow ingress
pvc 0/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 60.a.a.53 255.255.255.252
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
ip address negotiated
ip mtu 1452
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname kewpi@tmnet
ppp chap password 0 tmnet123
ppp pap sent-username kewpi@tmnet password 0 xxxx
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 60.b.b.b 0.0.0.3
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 60.51.196.0 0.0.0.255 218.b.b.0 0.0.0.255
access-list 101 remark CCP_ACL Category=2
access-list 101 remark IPSec Rule
access-list 101 deny   ip 60.a.a.0 0.0.0.255 218.b.b.0 0.0.0.255
access-list 101 deny   ip 60.a.a.0 0.0.0.255 175.b.b.0 0.0.0.255
access-list 101 permit ip 60.a.a.52 0.0.0.3 any
dialer-list 1 protocol ip permit
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 101
control-plane
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
kewpie-mlk#
Mohd - Those several people are correct.  You should build the VPN tunnel on the ASA rather than the 887's based on your design.  Looking at your tunnel, you only allowed ACL100.  So, those 2 networks are only going to pass through the VPN.  Now you are also doing PAT on you ASA.  You're traffic will not know how to get to your 192.168.x.x subnets this way.  This doesn't seem to be a routing issue, but more like a VPN issue.
As for the one-to-one NAT, you need to build that on the ASA, not the 887.  My impression was since you did not have VPN on the ASA.  NAT could work.  I highly suggest you rebuild the VPN on ASA.
Regards.
IcebergTitanic
Dear all,
So i need to down/delete the VPN from 887 right. Or should i use normal ADSL modem
Now i want to config below at both ASA 5510 site.
Plz review it. Is it OK?
site A
access-list VPN_cryptomap extended permit ip 192.168.5.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list Inside_nat0_outbound extended permit ip 192.168.5.0 255.255.255.0 192.168.0.0 255.255.255.0
nat (Inside) 0 access-list Inside_nat0_outbound
crypto IPSec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto IPSec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto IPSec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto IPSec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto map VPN_map 10 match address VPN_cryptomap
crypto map VPN_map 10 set peer 60.a.a.53
crypto map VPN_map 10 set transform-set ESP-AES-256-SHA
crypto map VPN_map interface outside
crypto isakmp policy 10 authentication pre-share
crypto isakmp policy 10 encryption aes-256
crypto isakmp policy 10 hash sha
crypto isakmp policy 10 group 5
crypto isakmp policy 10 lifetime 86400
crypto isakmp enable outside
tunnel-group 60.a.a.53 type ipsec-l2l
tunnel-group 60.a.a.53 IPSec-attributes
pre-shared-key kewpievpn
site B
access-list VPN_cryptomap extended permit ip 192.168.0.0 255.255.255.0 192.168..0 255.255.255.0
access-list Inside_nat0_outbound extended permit ip 192.168.0.0 255.255.255.0 192.168.5.0 255.255.255.0
crypto map VPN_map 10 set peer 218.b.b.b
tunnel-group 218.b.b.b type ipsec-l2l
tunnel-group 218.b.b.b IPSec-attributes
Mohd - Keep the 887 and just delete the VPN from it.  Just make sure you have the VPN ports permitted on your ACL facing your outside interface on your ASA.
As for your configuration, I would flip the ACL around:
SiteA:
access-list VPN_cryptomap extended permit ip 192.168.0.0 255.255.255.0 192.168.5.0 255.255.255.0
SiteB:
The rest of your config looks good.
Hope this helps.
IcebergTitanic
Yep, that should do it. I can't remember if you need to adjust your outside interface ACL or not. You might need to do a blanket allow on that as well:
access-list outside_in line 1 permit ip 192.168.5.0 255.255.255.0 192.168.0.0 255.255.255.0
Personally, I would also move the IP's into object-groups just for clarity:
object-group network SiteA_local
network-object 192.168.0.0 255.255.255.0
object-group network VPN_Peers
network-object 192.168.5.0 255.255.255.0
Then you can adjust your access-lists to just use the object-groups. That way, if you add more sites, you just add them to the object group, rather than having to adjust all your acls.
