ether-channel configurations
Tom Prevost
There is a command in IOS XR - "bundle minimum-active links 2"  that will take the bundle-ether interface down if the an interface goes down.  There is NOT an equivalent command in standard IOS.  Does anyone have a solution/workaround to drop a port-channel if one of the physical interfaces goes down?
Tom Prevost
correction - if one of the physical interfaces goes down.....
Hi thomas,
I am using below command
int port-channel 1
channel-group minimum active 2
but it depend upon platform and IOS whether it is supported or not
hope this help
mahesh
