Trouble with BGP Failover
dpoehls
Hello there,
We are multihoming using two 7600 routers, each to a separate ISP.  The two 7600's then have an iBGP peering between them.  I am preferring routes to the first ISP using local preference so if I do a "show ip bgp summary" I see the following (essentially) on each router:
Router 1:
x.x.x.x (Primary ISP Peering)     Received routes 300000
y.y.y.z (Router 2)     Recieved routes 100 (routes directly to Backup ISP)
Router 2:
z.z.z.z (Secondary ISP Peering)     Received routes 300000
y.y.y.x (Router 1)     Recieved routes 299900
The issue is, that if I have an issue with the Primary ISP (either the BGP session drops or I lose a lot of upstream routes), the routes shared in the peering between the 2 routers do not change.  So even though most or all of the 300000 routes to the Primary ISP are lost, those changes are not getting passed on to Router 2.   Thus, Router 1 has only 100 known routes to the internet, and Router 2 has 299900 routes to nowhere!
I can get things working again by clearing the session between the 2 routers, but I have to do this manually.
Question then:  Why is this not happening automatically, and is there configuration I can change that will make it so?
Please let me know if more information is needed.  I just don't see what I'm missing.
Thank you!
7 Replies 7
andrew.prince
Level 10
Level 10
Post your config for review, remove any sensitive information - but include your
route-maps, as-path lists etc
I sincerely hope this isn't the most confusing thing ever.  There are some other BGP peerings on these routers, but this should be all config relevant to this issue.
Thanks for taking a look!
***Router 1***
interface GigabitEthernet4/12
description Connection Router 1 -> Router 2
ip address x.x.x.y 255.255.255.252
interface GigabitEthernet7/6
description Connection to ISP_1
bandwidth 1000000
ip address y.y.y.x 255.255.255.252
speed nonegotiate
no cdp enable
router bgp XXXXX
bgp log-neighbor-changes
neighbor y.y.y.y remote-as YYYYY
neighbor y.y.y.y version 4
neighbor y.y.y.y activate
neighbor y.y.y.y prefix-list DENY-LEARNED in
neighbor y.y.y.y route-map UPSTREAM_PROVIDER in
neighbor y.y.y.y route-map ANNOUNCE-ISP_1 out
neighbor x.x.x.z remote-as XXXXX
neighbor x.x.x.z activate
no auto-summary
no synchronization
network ???.???.???.??? mask ???.???.???.???
ip as-path access-list 1 permit ^(YYYYY)(_\1)*$
ip as-path access-list 2 permit ^(ZZZZZ)(_\1)*$
ip as-path access-list 3 permit ^YYYYY_
ip as-path access-list 4 permit ^ZZZZZ_
ip as-path access-list 5 permit ^ZZZZZ_SPECIFIC_CUSTOMER$
ip prefix-list DENY-LEARNED seq 1 deny ???.???.???.???/??
ip prefix-list DENY-LEARNED seq 2 deny ???.???.???.???/??
ip prefix-list DENY-LEARNED seq 9 permit 0.0.0.0/0 le 24
ip prefix-list DENY-LEARNED seq 10 permit 0.0.0.0/0 ge 1
route-map UPSTREAM_PROVIDER permit 5
description RESET WHOLESALE
match ip address prefix-list WHOLESALE-NETWORKS
set local-preference 70
route-map UPSTREAM_PROVIDER permit 10
description prefer ISP_1 1-hop routes
match as-path 1
set local-preference 500
route-map UPSTREAM_PROVIDER permit 20
description prefer ISP_2 1-hop routes
match as-path 2
set local-preference 400
route-map UPSTREAM_PROVIDER permit 25
description prefer SPECIFIC_CUSTOMER ROUTES to go out ISP_2
match as-path 5
set local-preference 350
route-map UPSTREAM_PROVIDER permit 30
description prefer ISP_1 to ISP_2
match as-path 3
set local-preference 300
route-map UPSTREAM_PROVIDER permit 40
description set ISP_2 as Backup
match as-path 4
set local-preference 200
route-map ANNOUNCE-ISP_1 permit 5
match ip address 40
route-map ANNOUNCE-ISP_1 permit 10
match ip address 42
route-map ANNOUNCE-ISP_1 permit 20
match ip address 45
route-map ANNOUNCE-ISP_1 permit 25
match ip address 46
route-map ANNOUNCE-ISP_1 permit 30
match ip address 48
route-map ANNOUNCE-ISP_1 permit 35
match ip address 49
***Router 2***
ip address x.x.x.z 255.255.255.252
interface GigabitEthernet7/3
description Connection to ISP_2
ip address z.z.z.x 255.255.255.252
no cdp enable
router bgp XXXXX
neighbor z.z.z.z remote-as ZZZZZ
neighbor z.z.z.z version 4
neighbor z.z.z.z activate
neighbor z.z.z.z route-map UPSTREAM_PROVIDER in
neighbor z.z.z.z route-map ANNOUNCE-ISP_2 out
neighbor x.x.x.y activate
neighbor x.x.x.y remote-as XXXXX
no auto-summary
no synchronization
ip prefix-list PREFER-ISP_2 description Route these specifically to ISP_2
ip prefix-list PREFER-ISP_2 seq 10 permit ???.???.???.???/??
match as-path 1
match as-path 2
match as-path 5
route-map UPSTREAM_PROVIDER permit 27
description Specifically route to ISP_2
match ip address prefix-list PREFER-ISP_2
set local-preference 325
match as-path 3
match as-path 4
route-map UPSTREAM_PROVIDER permit 50
description EXPLICIT PERMIT
route-map ANNOUNCE-ISP_2 permit 5
match ip address 40
route-map ANNOUNCE-ISP_2 permit 20
match ip address 45
route-map ANNOUNCE-ISP_2 permit 25
match ip address 46
set as-path prepend XXXXX
route-map ANNOUNCE-ISP_2 permit 30
match ip address 48
route-map ANNOUNCE-ISP_2 permit 35
match ip address 49
I did not see the prefix list WHOLESALE-NETWORKS and access list 40,42,45,46,48 and 49. Can you post the full configs?
regards
Shivlu Jain
http://www.mplsvpn.info
Hi ,
Could you post from Router2
sh ip bgp y.y.y.y (y.y.y.y the IP on the neighbor from the Router1 )
or
sh ip route y.y.y.y
This route should have the next hop to the segment between the router1 and router2 and vice versa.
The problem could be the reachability of the next hop advertised by BGP ( the next-hop of the external routes doesnt change between Router1 and Router2 ). You could configure a static route on both routes for the interconection segments.
Dan
Please confirm,
1- Is there any device between two 7600 routers. If yes and if you have not enabled "ip path mtu discovery" then i would suggest to enable in all device in between. (To ensure your BGP packet will be >536 bytes and takes less time to send all the routes across bgp peer)
Next
use next-hop-self command with your ibgp neighbor  to change the next hop to that of router-1-2 when it propogate route to router2-1
Also as a short solution you can give "ip mtu 1500" interface command for connecting interface between two routers.
and also check if there is log in router 1 for memory issue as it will have to hold aroung 6lacs routes
this is a my thought and exact issue can be known with few outputs.
1- sh ip bgp neighbor (ibgp) from both router
2- sh ip route summary from both router
3- sh ip bgp x.x.x.x (any internet route) from both router
4- sh ver
mahesh
"next-hop-self" required between router 1 & 2 on the neighbor statements.
Hello Dpoelhs,
may I ask you why you are trying to set local preference for routes with an AS path starting with ISP2 ASN in the route-map of routes received by ISP1?
this is not correct, you need to increase local preference for these routes on R2 only on eBGP session with ISP2.
also both route-maps applied on received routes should have a final action like that means accepts everything with standard attributes ( local pref 100)
I don't see this final clause in first route-map applied on R1 if it is really missing you have a trouble.
The route-maps must be different to provide different local preference to different routes. They shouldn't be equal as explained above
Local preference is AS wide so to prefer a route received on Rx you should set local preference for that route on Rx only not also on Ry on the session with the other provider
Hope to help
Giuseppe
