Etherchannel module
rhltechie
hi All,
I need another fast ether int on my 2800 series router. I found the HWIC-4ESW on cisco's site. I notice that it says " Layer 2 Ethernet switches with Layer 3 routing capability. (Layer 3 routing is forwarded to the host, and is not actually performed at the switch.)."
I understand basically what this means, but does it at all mean that I will have issues placing an ip address on the interfaces as this is L3?
TIA,
R
5 Replies 5
globalnettech
Level 5
Level 5
the HWIC-4ESW requires you to configure inter-VLAN routing on the 2800 router (the host). So, basically, you put the FastEthernet interface into a VLAN, and then you configure a VLAN interface on the router, similar to the following example:
interface FastEthernet0/0/1
switchport access vlan 10
interface Vlan10
ip address x.x.x.x y.y.y.y
You cannot directly put an IP address on the interfaces of the HWIC-4ESW, since these are layer 2 interfaces only. Does that make sense ?
GNT
Roberto Salazar
Level 8
Level 8
the 4 faste interfaces/port on HWIC-4ESW are layer 2 ports meaning they are switchports you can enable routing by creating an SVI or interface vlan associated to the vlans assigned to those ports. I do not have the exact IOS version but there is an IOS version where the 4 switcports can also be a L3 interface much like an interface on 3550 or 3750 when you do a "no switchports" and assign an IP address that essetailly make that interface/potr a L3 interface. so, all in all I do not see any issue.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802c6bb6.html
Please rate helpful posts.
Is there an easier way for me to add L3 ports to my router?
I did not do a thorough search on CCO but it does not look like you have many choices and the 4ESW will give you a lot of port density and it's supported for certain on 28xx.
It looks as though the hwic only supports L3 by being assigned to a SVI. I have not done this, but I am assuming how this works is you create a vlan int on the router and then assign the port to a specific vlan. does this function exactly as having the ip directly on the int?
TIA,
R
