Etherchannel question
att-sgcops
I have 2 ethernet modules on my 6509, can I configure the etherchannel on 2 ports from different module? for example port 1 from module 1 and another port 1 from module 2.
jolmo
Level 4
Level 4
Yes. Use same speed and duplex mode for both ports.
Hope this helps
Anand Narayana
Level 6
Level 6
YES you can do ether-channelling one on module 1 & remaining on different modules within the switch. u can also do ether-channelling in a stackable switches as the switches will be considered as 1 single unit.
command for cisco 6509 CatOS as follows.
Cat6509>(enable) set port channel 1/1
Cat6509>(enable) set port channel 2/1
Cat6509>(enable) set port channel 3/1
Cat6509>(enable) set trunk 2/1 on dot1q
Cat6509>(enable) set trunk 3/1 on dot1q
Cat6509>(enable) set port channel 1/1 mode on
Cat6509>(enable) set port channel 2/1 mode on
Cat6509>(enable) set port channel 3/1 mode on
hope this helps.
rate this post.
ajagadee
Yes, Etherchannel between ports on different modules is supported.
This is a cool feature, since it provides module redundancy.
Please refer the below URL for details on Configuring Layer 3 and Layer 2 EtherChannel
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008007e6d3.html
Arul
