Ethernet over GRE
Dear all, i found a Cisco config in IOS XE 3S which you can configure multiple vlan over GRE:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/interface/configuration/xe-3s/ir-xe-3s-book/ir-eogre.html
"tunnel vlan vlan ID " , is this also supported on ISR 4321 router with IOS XE SW.??
0 Replies 0
