Ethernet Virtual Circuit question
aljoush12
Hello Experts,
I am new to EVC. I am trying to configure evc where device B receives an untagged packet and pushes vlan 22 onto the egress and device C receives it and pops the tag and sends it to D. I need to create multiple service instances with encapsulation dot1q on the port channel because encapsulation untagged doesn't support on multiple service instances on a same interface. Routers B and C are ASR920.
        Port-channel 1
A ------> untagged packet --------> B -------> tagged with vlan 22 -----------> C --------> untagged packet -------> D
I tried this config below on Po1 but it didn't work. Could please let me know if this is doable or if I am doing wrong here? I appreciate your help.
Router B:
interface Port-channel1
 no ip address
 service instance 22 ethernet
  encapsulation dot1q 22
  rewrite ingress tag push dot1q 22
  bridge-domain 22
  rewrite ingress tag push dot1q 22 symmetric <<- this need to do reverse when packet out do in both router
9 Replies 9
  rewrite ingress tag push dot1q 22 <<- add this on Router-B and Router-C interface that receive untag traffic not config it under Port-Channel.
Thanks A Lot
MHM
Hi MHM,
Thank you for your reply. I have two members on the port-channel 1. I have the config below on both routers B and C. Are you suggesting to configure it on the member interfaces but not on the Port-channel interface?
 no ip address
  bridge-domain 22
interface1-B-PO
config this on interface not on PO nor it port member
Hi MHM,
Here is my config on Router B. Please let me know if this is what you are suggesting.
A ------> untagged packet --------> gi2 B gi1 -------> tagged with vlan 22 -----------> gi1 C  gi2--------> untagged packet -------> D
interface GigabitEthernet2
 no ip address
 negotiation auto
  bridge-domain 22
end
interface BDI22
 ip address 10.102.0.90 255.255.255.248
 vrrp 1 ip 10.102.0.89
 vrrp 1 priority 200
end
interface GigabitEthernet1
 no ip address
 negotiation auto
  channel-group 20 mode active
end
interface Port-channel20
 no ip address
 no negotiation auto
  bridge-domain 22
end
Yes exactly, you push the vlan22 tag in ingress of frame.
did you check this solution ?
note:- you must apply same in Router C
Hi MHM,
Please see my config below. I am not able to ping10.102.0.91 in Router C from Router B 10.102.0.90 since it is expecting the tag 22.
Router B
 no ip address
 negotiation auto
  bridge-domain 22
interface BDI22
 vrrp 1 priority 200
 no ip address
 negotiation auto
 no ip address
 no negotiation auto
  bridge-domain 22
Router C
 no ip address
 negotiation auto
  bridge-domain 22
 interface BDI22
 ip address 10.102.0.91 255.255.255.248
 vrrp 1 priority 200
 no ip address
 negotiation auto
 no ip address
 no negotiation auto
  bridge-domain 22
Hi MHM,
That did it. Thank you so much!
You are welcome
Have a nice weekend
MHM
