EVPN-MPLS Why MAC and IP Pair is not apper?
tamatsushita
I have configured EVPN-MPLS using CSR100v with CML.
Why is the Type-2 information "MAC and IP" missing?
Shouldn't this entry contain the IP address?
[2][10.255.0.4:20][0][48][5254001F1F37][0][*]/20
I attached the configuration.
PE4#show l2vpn evpn mac
MAC Address    EVI   BD    ESI                      Ether Tag  Next Hop(s)
5254.0001.8351 20    20    0000.0000.0000.0000.0000 0          10.255.0.2
5254.001f.1f37 20    20    0000.0000.0000.0000.0000 0          Gi3:20
PE4#show l2vpn evpn mac  ip
IP Address                EVI   BD    MAC Address    Next Hop(s)
PE4#
PE4#show bgp l2vpn evpn neighbors 10.255.0.2 advertised-routes
BGP table version is 12, local router ID is 10.255.0.4
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
              t secondary path, L long-lived-stale,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 10.255.0.4:20 (default for vrf VPN20)
 *>   [2][10.255.0.4:20][0][48][5254001F1F37][0][*]/20
                      ::                                 32768 ?
 *>   [3][10.255.0.4:20][0][32][10.255.0.4]/17
                      ::                                 32768 ?
 *>   [5][10.255.0.4:20][0][24][192.168.2.0]/17
                      0.0.0.0                  0         32768 ?
Total number of prefixes 3
Because PE dont have idea about user IP'
Config static IP and try ping other IP and then check type2 mac-ip
MHM
Thank for reply.
I tried your advise, but mac-ip is still missing.
PE4#show run interface bdi 20
interface BDI20
 vrf forwarding VPN20
 ip address 192.168.2.254 255.255.255.0
 no mop enabled
 no mop sysid
end
PE4#ping vrf VPN20 192.168.2.1
Sending 5, 100-byte ICMP Echos to 192.168.2.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
PE4#show arp vrf VPN20
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  192.168.2.1             0   5254.001f.1f37  ARPA   BDI20
Internet  192.168.2.254           -   001e.144f.93bf  ARPA   BDI20
                      ::                                 32768 ?
                      ::                                 32768 ?
                      0.0.0.0                  0         32768 ?
PE4#
