Exclude host from VPN tunnel
Group IT
I have a router setup at a remote site to to connect to HQ (ASA) via VPN IPsec tunnel.
I have a device at the remote site, which I want to exclude from the tunnel (so it can access the internet unfiltered etc). Basically, I guess it's split-tunnelling for a single host.
Just can't get my head around how to do it.
HQ (ASA):
  • Public IP: 81.128.123.123
Remote Site (router):
  • Public IP: 77.240.123.123
  • LAN: 10.11.102.0/24
Device to exclude: 10.11.102.136
The general tunnel works okay (intermittent speed issues, but that's another matter), but as soon as I deny the device's IP in the VPN-TRAFFIC ACL, the device can't get out at all. I assume it;s something to do with NAT, but I'm not so hot with Cisco stuff yet.
Can someone please give me a hand?
ROUTER CONFIG:
Current configuration : 3983 bytes
! Last configuration change at 17:25:39 gmt Wed May 10 2017 by ejohnson
version 15.3
service password-encryption
hostname rtr-h000356
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa authorization exec default local
aaa session-id common
clock timezone gmt 0 0
clock summer-time gmt recurring
ip flow-cache timeout active 5
ip domain name my-domain.local
ip name-server 10.11.1.217
ip cef
no ipv6 cef
object-group network HGL-IPs
host 81.136.123.123
host 81.128.123.123
host 194.75.123.123
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
crypto isakmp key xxx address 81.128.123.123
crypto ipsec transform-set TS esp-aes esp-sha-hmac
mode tunnel
crypto map VPN-TO-HQ 10 ipsec-isakmp
set peer 81.128.123.123
set transform-set TS
match address VPN-TRAFFIC
interface FastEthernet0
no ip address
shutdown
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
description link to switch (VLAN192)
switchport access vlan 192
switchport mode trunk
no ip address
interface FastEthernet3
description LAN (VLAN102)
switchport access vlan 102
no ip address
interface FastEthernet4
description WAN link
ip address 77.240.123.123 255.255.255.0
ip nat outside
ip virtual-reassembly in
ip tcp adjust-mss 1340
duplex auto
speed auto
no cdp enable
interface Vlan1
no ip address
shutdown
interface Vlan102
description Site business data
ip address 10.11.102.254 255.255.255.0
ip helper-address 10.11.200.3
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
interface Vlan192
description Voice VLAN
ip address 192.168.1.254 255.255.255.0
no ip proxy-arp
ip nat inside
no ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 1000
ip flow-export source FastEthernet4
ip flow-export version 9
ip flow-export destination 10.11.1.226 2055
ip nat inside source list NATIN interface FastEthernet4 overload
ip nat inside source static tcp 10.11.102.102 25 interface FastEthernet4 25
ip route 0.0.0.0 0.0.0.0 77.240.123.123
ip access-list standard NATIN
permit 192.168.1.100
ip access-list extended VPN-TRAFFIC
permit ip 10.11.102.0 0.0.0.255 any
Mark Malone
did you try this in the order to exclude it from the tunnel and allow it ion the NAT acl
permit 10.11.102.136
deny ip host 10.11.102.136
